Old 05-04-2016, 12:42 PM   #11
I would think changing the jets in the fuel system would compensate for the alttitude.
AJAbbott is offline   Reply With Quote
Old 05-04-2016, 12:47 PM   #12
There is a screw you can adjust, at least on ours. I forget where or what but the guys at Super Gen showed me several years ago since we we're headed from NYS to Rocky Mtn Nat Park and camping at 8500 ft. Never needed to make the adjustment though.
John M
2013 GMC Sierra 2500DH CC, 4x4, D/A
2016 Forest River Vengeance 25V TT/TH
johnm1 is offline   Reply With Quote
Old 05-04-2016, 01:05 PM   #13
I was wanting to do the same thing and when I called and talked to Champion tech rep he told me that paralleling the 2 2000 units wouldn't be enough and I would have to paralled 2 3100 units to start and run it. It seemed like a lot to me but that's what I was told. So for now I am left questioning what I need as well since i'm in the same situation as you.
Nick and 4 kids
2011 Chevrolet 3500HD LTZ Crew cab Duramax
2017 Sandpiper 372LOK
ndwiginton is offline   Reply With Quote
Old 05-04-2016, 01:21 PM   #14
Champion 2000w gen
I originally had the same problem with 2 2000w Yamahas in parallel. Prior to installing a hard start capacitor I was able to start the AC by turning on the fan only for a minute and then started the AC. You might give that a try. Good luck.
tbolt69 is offline   Reply With Quote
Old 05-04-2016, 02:43 PM   #15
What?
I've been reading on blogs & Youtube that with an easy start you can run an a/c on a Honda 2000. Has anyone here confirmed that?
mnoland30 is offline   Reply With Quote
Old 05-04-2016, 04:07 PM   #16
Honda 2000
I have the Honda 2000 gen, and have run my 15000 A\C you need to buy the companion Honda 2000 gen. Although I have done this I would not recommend this since it appears to overwork the gen. I have two Honda gen (the regular gen and the companion) by paralleling these unit you can run your a\c and anything else you need to run without any problems
bemilner is offline   Reply With Quote
Old 05-04-2016, 04:21 PM   #17
Powerman's Avatar
I just received my champion 3100 and in the book they said that you can call them and they'll send you the high altitude jets. Might be different for 2000's.
MARINOS
2015 PRIME TIME AVENGER 28 DBS
2016 GMC SIERRA DENALI 2500 HD
Powerman is offline   Reply With Quote
Old 05-04-2016, 04:33 PM   #18
If you are always above that altitude you can try to rejet the carb.
pdqparalegal1 is offline   Reply With Quote
Old 05-04-2016, 05:01 PM   #19
bikendan's Avatar
I believe Champion does have high altitude jets for the 2000w.
Dan-Retired Firefighter/EMT
Equalizer WDH and Prodigy BC
Old 05-05-2016, 06:54 AM   #20
I had a similar issue with my Champion as I live at 6000 feet. I was able to order from Champion at no cost to me a high altitude carb jet. Once I installed this and made sure my water heater and fridge were on propane the a/c unit fired up. Works great at altitude up to 10,000 feet. Runs a bit rough under 3,000 feet.
Airborne is online now   Reply With Quote
generator, inverter
