Old 05-05-2016, 07:11 AM   #21
CP3
Thanks for the suggestion on the high altitude jets. I'll call them today to see if they'll send me some. I'll report back with an update once I get them.
2016 Cherokee 274DBH
2013 Ford F-150 FX4 Ecoboost Max Tow
Husky Centerline HD
CP3 is offline   Reply With Quote
Old 05-05-2016, 08:40 AM   #22
You could try something like this.[URL]id144248.webhosting.optonline.net/microair.net/merchantmanager/product_info.php?cPath=4&products_id/URL]
2016 Ford F250 XLT 4X4 6.2L
Hensley Arrow
Nights camping in 2017: 20 nights
Miles traveled in 2017: 1,530
uhduh camping is online now   Reply With Quote
Old 05-05-2016, 08:42 AM   #23
Might have send better link later, not sure that one will work.
Hensley Arrow
Old 05-05-2016, 11:47 AM   #24
CP3
I emailed Champion last night and here's the response I got:
We do not have a jet available for this size engine, however you can add some holes to your air filter cover (drill 3 to 5 holes to allow for better breathing) and you can remove the spark arrestor from the muffler. If the spark arrester is required at your campground then be sure you clean it before your trip. Also, clean your spark plug at every 50 hours as well. You can also move to a hotter spark plug and you can close the spark plug gap to 0.018 to 0.020.
So I called them to confirm and the guy I spoke with said the same. He also said the 2000's in parallel are rated to run/start the 15k AC AT SEA LEVEL. He said above 5k elevation they're losing 12-15% of rated output and they probably won't start the AC.
So there I have it. Time to drop another $2k+ on a bigger generator or live without AC.
Husky Centerline HD
Old 05-05-2016, 12:37 PM   #25
I have to wonder if your parallel cable is bad. Isn't the whole point is that it combines the two together so you have 3400 watts to use? If so you should have no trouble even if only 3000 watts are available.
2010 F250 5.4L 3.73
2011 Flagstaff 831FKBSS
Equal-i-zer 4pt 12K
2010 F250 4X4 5.4L 3.73 LS
EQUALIZER E4 1200/12000
Old 05-05-2016, 12:39 PM   #26
http://www.microair.net/main/default.html
Look for soft start devices
Hensley Arrow
Old 05-05-2016, 01:32 PM   #27
Originally Posted by CP3 View Post
[I]We do not have a jet available for this size engine,
[/FONT]
Just because they don't have one doesn't mean a different jet is not available. I doubt the carb or jets on the motor is proprietary. Remove the jet or get the carb mfr/model number and contact any motorcycle/snowmobile/lawnmower/etc dealer to see if it can be cross referenced.
Also, check out this document. It shows high altitude jets.
http://www.championpowerequipment.co...stallation.pdf
Lee and Anne
2016 F250 2WD CC SB XLT 6.2 3.73 3,295 lb payload cap.
2014 Salem Hemisphere 282RK 8k lbs loaded, Equal-i-zer WDH, TST 507 TPMS
2017: 4 nights camped, 12 booked
Teamfour is offline   Reply With Quote
Old 05-05-2016, 04:29 PM   #28
Re jetting
Listen after racing go-carts with my daughter in the World Karting Association all over the country I have learned a thing or two about re-jetting a carborator.
My recommendation is buy a set of OEM jets and a set of pin drill bits.
Using the pin bits find the drill bit that fits the hole in the OEM jet.
Now comes the trial and error
Take the next size bit and enlarge the hole by turning the bit with your fingers till you drill through the jet.
Install jet test unit.
If desired results are not achieved repeat above steps till they are.
Just as a side note buy a couple extra jets.
AJAbbott is offline   Reply With Quote
Old 05-06-2016, 12:22 AM   #29
At sea level you have 3400 watts.
For every 1000 foot gain in altitude you have 3% loss in engine power and 3% loss in electrical generation capacity PROVIDED you have the desired air/fuel mixture (jetting) at that altitude. Since you are not rejected, you are probaly losing more than 5% in electrical generation capacity.
Your best bet is to lean our your jets.
On my Boliy generator, I removed the jet, soldered it shut, and redrilled a smaller hole in it. I then and check plug for mixture and resoldered-redrilled again as necessary.
On another note: Where the heck are you camping in CO that requires airconditioning? We never run a/c in CO where we boondock in the back country and we always run heat each night ;-)
Skyliner is offline   Reply With Quote
Old 05-06-2016, 05:09 AM   #30
CP3
I may try messing with the jets myself but with my luck I'd make it worse haha.
I'm in NM, and we have several trips planned for Elephant Butte lake this summer. No shade and regularly 100+ even at 4500'. With a "needy" wife and two young girls I'll definitely need the AC. I could just plug in but that's boring!
Husky Centerline HD
generator, inverter
