Old 05-03-2016, 10:15 PM   #1
CP3
Parallel Champion 2000w inverter generators won't start 15k AC
Bare with me here but I'm at a loss as to what I need to do from here. I have two Champion 2000w generators (73536i and 73540i which I confirmed with Champion can be run parallel) that will/can not start my 15k BTU AC. I've even tried running a hard start capacitor hoping it would allow them to start but no go. I live around 5800' elevation and will be boondocking anywhere between 4500' - 9000' so I know elevation is having a significant effect on the generators output.
So I suppose my question is, does anyone have a suggestion on getting this setup to work? I don't want to have to buy a huge 4000 generator but I have to be able to run the AC or wife will be miserable. Any and all suggestions welcome. Or if anyone can advise what generator they're running their 15k AC on would be appreciated as well.
2016 Cherokee 274DBH
2013 Ford F-150 FX4 Ecoboost Max Tow
Husky Centerline HD
CP3 is offline   Reply With Quote
Old 05-03-2016, 10:50 PM   #2
HONDAMAN174's Avatar
Not in Eco mode right?
2014 Evo 2850 "Woodstock"
2011 Toyota Tundra "Clifford"
Just glad to get away
Old 05-03-2016, 10:58 PM   #3
CP3
Right. I tried it both ways as it will kick up when it sees higher demand. But even with Eco off, they go into overload and stop sending power.
Husky Centerline HD
Old 05-04-2016, 06:09 AM   #4
fonzie's Avatar
and you have water heater and fridge on propane only?
Fonzie
Old 05-04-2016, 07:46 AM   #5
CP3
Yes, both on propane only and both off.
Husky Centerline HD
Old 05-04-2016, 07:46 AM   #6
We have the same generators (maybe diff part #'s though) but they ran our 15k unit ok. We had to manage the power buy making sure I flipped all breakers until after the AC was running. After it was "warmed up" I could add a few things. Make sure your charger is off while trying to start the AC. That thing can be a power pig.
John M
2013 GMC Sierra 2500DH CC, 4x4, D/A
2016 Forest River Vengeance 25V TT/TH
johnm1 is offline   Reply With Quote
Old 05-04-2016, 09:15 AM   #7
MrNiceGuy's Avatar
Are you using a ground/neutral plug in one of your Champion outlets? Will other appliances work like your microwave? Are you able to measure the voltage leaving the Champion?
2015 Crusader 315RST
2011 Silverado 2500HD
MrNiceGuy is offline   Reply With Quote
Old 05-04-2016, 09:35 AM   #8
CP3
Maybe I'll try that. Being that yours ran it, but it appears to be "barely" leads me to believe I'm SOL due to the elevation I'm trying to run these at. I think if I were at sea level they would be fine but since I'm losing at least 20%, I think I've found my problem.
Sorry for my ignorance but I'm not sure what you mean here. I'm running whatever is on the parallel kit which I believe is grounded? Yes the microwave powers up and runs well, even with the generators on Eco mode. They increase the RPM on startup but settle down once it's going. I do have a multimeter so I think I'll see how much power I'm getting out of them, I haven't done that yet.
Husky Centerline HD
Old 05-04-2016, 09:54 AM   #9
MrNiceGuy's Avatar
Sorry for confusing you. A ground/neutral plug is used in an inverter type generator to solve a grounding issue while using an Electric Management System (EMS) like the unit from Progressive Industries. I do think a lot of your questions will be answered when you plug your voltmeter in and find what voltage the Champion is putting out.
Old 05-04-2016, 10:17 AM   #10
Sorry - forgot to also tell you to call Super Gen Products. They're in Newark, NY (I know the location doesn't help you much). They are one of the only (if not the only) approved service center for Champion. I luckily live ~45 min from them and they've helped me a few times. I remember something about a bad batch of "brains" for lack of another term and they ended up replacing mine. The owners father (?) worked for Champion and they know these things backwards and forwards and they give great advice over the phone 315-573-7887. I've never dealt with the California location.
I bought both of mine and the parallel, refurb'd, from them.
BTW: I've seen 1st hand in their shop what ethanol fuel does to the gas tanks. One of their best recommendations is to use ethanol free fuel to help avoid the rust in the tank.
John M
generator, inverter
