Old 12-15-2015, 05:04 PM   #1
Parallel Generator Help Please
Hi All,
I have a set of Generac IQ2000 generators & Parallel Kit on the way.
I have already installed an Progressive Industry EMS in my Micolite. From reading other threads I understand that Generators can not have a floating Neutral or the Energy management system will shut power off. I called Generac and found out the new IQ2000's do have a floating Ground. I have seen on treads where you can make a plug with Neutral and Ground connected with a wire and plug it into receptacle on generator to solve problem. My question is do I use 1 of these plugs on 1 Generator or being they will be paralleled together with generac parallel kit do I have to use 2 plugs, 1 on each generator?
rjssuzq is offline   Reply With Quote
Old 12-15-2015, 05:05 PM   #2
Who Dares, Wins
doc73's Avatar
One will do the trick.
Sent from my SAMSUNG-SM-G870A using Tapatalk
2015 ChevyHD D-Max
2018 Artic Wolf 315tbh8
doc73 is offline   Reply With Quote
Old 12-15-2015, 05:37 PM   #3
Thanks for quick reply doc. That's Great!
Old 12-15-2015, 05:51 PM   #4
There is an issue with PI's EMS using Yamaha's 2000W genny. PI recommends to bypass with these genny's to keep from harming EMS unit. I would check with Generac to make sure your genny operates in in true Sine wave before you do use it. You could bypass internally with included jumper or purchase/make a bypass switch if it does not. Installation is straight forward and easy enough, PI has installation video online.
2016 Ford F250 XLT 4X4 6.2L
Hensley Arrow
Nights camping in 2017: 20 nights
Miles traveled in 2017: 1,530
uhduh camping is offline   Reply With Quote
Old 12-15-2015, 07:06 PM   #5
I will call Generac tomorrow and see what they say. I remember reading that about Yamaha. I Hope the new IQ2000 is not the same.
Old 12-16-2015, 07:08 AM   #6
So far I have found this on a Amazon review of this generator:
Generac Power Systems, Inc. says:
Thank you for providing us with your detailed review of the iQ2000 portable inverter generator. Please know that the tube that you have identified serves the purpose of a drain valve for oil overflow/flooding; if the unit is flooded during attempted startup, this tube will allow the unit to drain via the carburetor. Also, the iQ2000 features a pure sine wave. We apologize that you had a difficult time verifying this information.
Hopefully this will help fellow Campers looking to use these generators with their EMS system. So the new Generac IQ2000 should work fine with your Energy management System without having to bypass it. Just by using a plug with Neutral and Ground wired together and plugged into one of the outlets on one of the paralleled generators. I will let everyone know how this works when they arrive and give a review of these new generators. They are going up against the Honda and the Yamaha.
So far I think they are already beating the Yamaha's because Generac has Pure Sine waves where Yamaha has Modified Sine waves which will not work with PI's EMS.
Old 12-16-2015, 11:03 AM   #7
"Yamaha has Modified Sine waves..."
First time I have heard of that.
Some real cheap inverter gennys have MSW, but I don't believe Yamaha is one of them.
2007 Surveyor SV230
- 200 Watts Solar/MPPT Controller - 230 AH Battery Bank - 600 watt PSW Inverter - (2) 2000 watt Inverter Generators - LED Lighting
Boon Docking 99% of the time.
2009 F150 - 5.4 Litre - Tow Package
boondocking is offline   Reply With Quote
Old 12-16-2015, 11:27 AM   #8
Kenny kustom's Avatar
Name:	ImageUploadedByForest River Forums1450286845.051838.jpg
They have a high current 2400 that they claim will run most 13.5 ac.
2016 Sabre 36QBOK
2015 Ram 3500 CUMMINS
I am nice!
2017 Dynamax Isata 4
Old 12-16-2015, 12:52 PM   #9
Left Coast
Had to do plug thing with Hondas
Old 12-16-2015, 01:56 PM   #10
TGR
TGR's Avatar
As I understand the issue, the Yamaha EF2000iS produces a pure sine wave that is great for computers and other critical devices. However, when an air conditioner starts, the very heavy load will cause a generator's output sine wave to distort, which can harm the Progressive Industries' EMS units. The bigger the surge demand from the A/C, the greater the problem.
Rather than checking with the generator manufacturer, it would be better to get an answer from Progressive Industries. They say they can't test every generator on the market so they may not have an answer. Additionally, their literature, under "Warnings," says, "Never plug EMS into an inverter."
I am aware that some people use their inverter generators with their EMS and have no issues. Again, call Progressive Industries for their take.
2015 Wildcat 282 RKX
2011 F350 Lariat, 6.7 L. Diesel, 8 ft., SRW, Reese R20
TGR is offline   Reply With Quote
generator
