Old 09-07-2015, 02:35 PM   #1
Parasitic Battery Drain
I want to check my coach for a possible (abnormal) parasitic drain, but I don't know what's "normal". Using my multimeter I get a reading that fluctuates between 0.574 and 0.604 amps. So my questions are:
1. Is that fluctuation normal?
2. Are those numbers high, normal, or what?
Nothing is turned on; not even the refrigerator. But, there is the CO/Propane detecter, TVs are plugged in, and the radio is probable drawing some for the clock and stuff.
DnL is offline   Reply With Quote
Old 09-07-2015, 04:00 PM   #2
Rrickim63's Avatar
What if you disconnected each item listed and checked again. It sounds reasonable, but not 100 percent. Sure.
2006 Roo 23B hybrid
1999 Chevy Silverado Ext cab 4.8L with tow package
Rrickim63 is offline   Reply With Quote
Old 09-07-2015, 04:07 PM   #3
Blackhat6mike's Avatar
Send a message via Skype™ to Blackhat6mike
That sounds about normal for CO/propane and radio draw. Might want to check your TV antenna amp if you have one. If you want to disconnect them all, use a disconnect switch at the battery.
2013 Silverado 2500 HD Duramax/Allison Tuned
Aviator Wright Flyer #1919
"First In, Last Out". 11B4Y
DAV, MOPH, VFW, 5/7 Cav,1/8 Cav Assoc.
11th ABN Pathfinder Co. N7MIP
Blackhat6mike is offline   Reply With Quote
Old 09-07-2015, 05:17 PM   #4
Your readings are pretty much where they should be. The fluctuation is normal too.
My 2012 T12SC A frame has a drain of about 0.3 amp. Like you, I see fluctuating values. You are measuring only a 30 milliamp (0.03 amp) fluctuation, which is very small. That most likely is coming from your detectors. Some detectors don't draw a steady amount of current. They take samples periodically, and then go idle between samples to save battery power. Depending on how many detectors are sampling at any one time... 0.03 amp fluctuation is very reasonable.
The total current is normal too. Your coach may have more smoke/propane/CO detectors than my A frame, so a reading higher than mine would be expected. If your TV is 12 volt it will be drawing a small amount of current to be able to respond to the remote control. Clocks, antenna amplifiers, furnace/AC controls... anything electronic can potentially draw a tiny amount of power when it is "off".
You can look into a solar panel and charge controller to offset that parasitic draw and keep the battery from running down. 0.6 amp at 12 volts is 7.2 watts, assuming that the sun doesn't shine 24 hours a day where you are, a 30 or 40 watt panel would be enough to replace during the day what has been used at night.
It is also possible for water to get in and cause a small current to flow, particularly with any external electrical equipment. Not uncommon to see rain getting into outside lights, and it can bridge the contacts in the switch. Not enough current flows to light the light, but enough that your meter can measure it. Slide outs? Check the wiring for any damage that might allow water in.
2012 T12SC
2011 Grand Caravan
Deemar is offline   Reply With Quote
Old 09-07-2015, 05:51 PM   #5
Thanks to all for your replies. Your input is a big help.
battery, drain
