Old 09-23-2014, 04:22 PM   #11
rip
rip's Avatar
When Herk mentioned "MAKE SURE you get the correct polarity! Bonding the hot to ground would be very bad for your inverter generator," and Mike mentioned miswiring the aftermarket kit may switch Hot and Neutral, I figured the idea of doing any kind of ground-to-whatever may produce an unexpected short.
Let us know if checking the wires (phase connections) on the Generac resolves your issue.
Ray
+ 2013 Rockwood Windjammer 2809W
+ 2008 GMC Sierra Crew Z71
+ 2002 Ford F-250 7.3L 4X4
rip is offline   Reply With Quote
Old 09-23-2014, 05:22 PM   #12
HONDAMAN174's Avatar
It's probably not miswired as I can bypass the PI and everything works fine.
2014 Stealth Evo 2850 "Woodstock"
2011 Toyota Tundra Rock Crawler TRD 5.7 "Clifford"
Just glad to get away
Old 09-23-2014, 08:40 PM   #13
rip
rip's Avatar
I thought everything works fine is why potentially dangerous reverse polarity (E1) is such a tranparent condition.
I used one of those tester plugs before I plugged my neutral-ground adapter plug into a generator socket. Also tested my generator's 30 amp outlet with a 30-to-15amp-prong-converter before I plugged in my RV.
Yeah, I know, no guts no glory, what a sissy.
Ray
Old 09-23-2014, 08:43 PM   #14
But that's the nice thing about electricity- if the magic smoke doesn't come out of all your equipment right away you are probably good!
