05-26-2018, 08:06 AM
PI EMS keeps shutting off power with Low Voltage E04.
I tried a neighbors pedestal and they are a consistent 116 volts. I talked to camp maintenance and he said it's Memorial Day weekend and a few are complaining about low voltage. But if my neighbor is a consistent 116 and mine is 106 dropping to 104 regularly, doesn't that indicate a problem with the pedestal?
The campground is packed and all the ACs are running.
Thanks.
Ron
Ron & Family
2017 Shamrock 23IKSS (Traded)
No longer active with Forest River Forum.
05-26-2018, 08:38 AM
the two pedestals (yours and neighbors) are probably on separate feed loops. it sounds like the loop yours is connected to has pretty heavy usage from all the pedestals on that loop. as usage (amperage) increases the voltage decreases. or possibly longer runs and / or high resistance connections on that loop. so what did the campground say they were going to do to correct it for you and the others?
2015 cardinal model 3825fl
2015 dodge ram 3500 dually
05-26-2018, 08:42 AM
Always Learning
The few times I’ve experienced this, the campground basically said, “well that’s too bad”. In one case. I could get by without A/C. In another, I found as long as I ran just 1 high use appliance, I could just barely get by.
My options were to leave, run a generator, or buy an AutoFormer.
Took me a while, but I finally ordered an autoFormer. It doesn’t help you this weekend, but does help you in the future.
05-26-2018, 08:53 AM
Loose connections or a worn out outlet could also be the culprit. Use an adapter and try another plug (50 or 30h if available.
2016 Georgetown 364TS
2017 Jeep Rubicon Recon toad
Nights Camped 2019 - 17
05-26-2018, 09:45 AM
There are 4 plug ins (4 sites) and they are all 30 amp. But I do like the idea of getting an adapter for 50 amp in the future.
Thank you.
Ron & Family
05-26-2018, 10:21 AM
Ok... Considering going into bypass mode. This is ridiculous... It's shutting off every 2 minutes after starting.
Anyone want to talk me out of it???
Ron & Family
05-26-2018, 10:24 AM
If you use your by-pass then don't use use your air conditioning...my opinion.
Fonzie
05-26-2018, 10:32 AM
Have you put your water heater and fridge on propane alone if possible to reduce load and maybe you can run AC with EMS in service?
Fonzie
05-26-2018, 10:36 AM
You can always do what most of my camping buddies have done, get rid of the EMS entirely. I was going to invest in one until about four of them told me the EMS caused too many problems between situations like yours and false errors. I'll just keep checking pedestals with a meter
Scott and Liz - Southern NM
2007 Chevy 2500HD Duramax
05-26-2018, 12:25 PM
You can check a pedestal with a meter and have acceptable voltage, but may drop considerably when under load. I wouldn’t be without one.
05-26-2018, 12:34 PM
I wouldn't be without the EMS even though it does cut off with low power.
Putting up with no power is a whole lot better than replacing appliances that burn out.
If you really want to ditch the EMS temporarily in that campground, at least get a surge protector that checks for reverse polarity and open ground.
2015 Dynamax REV 24TB class C
05-26-2018, 12:36 PM
The nice thing about the progressive is that it does have the bypass and the remote readout on the permanent unit. I would certainly NOT get rid of it altogether. It serves multiple purposes including surge protection. I personally don't want to have to replace all my electronics due to a surge that could have been prevented. It also serves to alert you to park power issues, which you can then decide how to address.
Running your A/C on low power is probably not a good idea. Your problem does indicate that this particular park electrical isn't well designed for the loads it incurs. I would consider trying another loop if possible, or another park.
I've had the reverse problem. The progressive has clicked off on a slightly high load that showed several volts lower (and acceptable) on my meter. Progressive told me that it was because their unit measures "True" RMS power. I just went in to bypass, but was comfortable because I had the information to make an informed decision.
That is the reason to keep it. It protects you and allows you to make an informed decision about how to use it.
Surge protectors are very important. I used to work as the buyer for a large electronics retailer and one of my product lines was surge protection. One of my customers had a new APC surge protector that was outlet mounted and fed all of his audio video equipment. A large lightning strike literally blew it off the wall and into a garbage can, where it caught on fire. None of his equipment was damaged. True story and it made me a believer.
Charlie
[SIGPIC]
2005 Coachmen Sportscoach Encore 380DS
2019 Jeep Wrangler Rubicon Unlimited
05-26-2018, 12:40 PM
According to the PI instructions, when you bypass the EMS, the surge protector still works. Maintenance came by and opened a main box that controls 12 sites. He said it was hot. He left it open. The box is now just warm and we have not lost any power. But I'm still in bypass mode.
Ron & Family
05-26-2018, 12:43 PM
Charlie
I agree with everything you said.... but this is Memorial Day Weekend! No way are they going to find another campsite.
05-26-2018, 12:46 PM
Right on. We have made a dozen calls within 30 miles. They have to hold back the laughter when we ask for availability.
Ron & Family
05-26-2018, 12:57 PM
Citrus County, Fl.
I had this problem during the Solar Eclipse Rally. Park had a bad feed and after repairing that my voltage was still low. Maintenance replaced the 30 amp breaker and it solved the problem.
I would not suggest bypassing if the power is low enough for the EMS to cut the power. It's doing the job it was designed to do.
2016 Forester 3011DS
2017 Toyota Corolla SE toad
99 Terry 31G
05-26-2018, 02:51 PM
Low voltage, the "Camper's Curse"
This is a wide spread problem, and as we get more electrical toys, it gets worse, as some campgrounds haven't been able to keep up with electrical demands. Having said that, we need to find a solution that works. In my own case, being a retired Industrial Electrician, I bring some differing ideas to the figurative table, not all of which will be appropriate in all cases.
First, while I don't have an EMS, I do have a very effective surge suppressor from GE, permanently installed, and have equipped my power cord with a high quality Hubbell twist lock connector on the RV end, mating with a connector mounted with a digital volt meter inside the "cord compartment". All of my extension cords are heavy SOW cord, and likewise equipped with twist lock connectors. (We go to a lot of Bluegrass Festivals, and often have to put out extra cord) The low voltage/high voltage situation isn't a problem any longer, as I installed a constant voltage transformer, gleaned from an industrial surplus yard. It is made by Sola, good for 4KW, and can be wired for either 120 or 240 volts or both. With an input of about 80 to 140 volts, the output is stable at 125 volts, as long as the power source is 60Hz. These devices, also called "ferro-resonant transformers" are widely available, but not cheap. I would definitely go with used again.
I'm also a believer in the Heart Interface type inverter, which offers 2,000 watts of 120 volts, automatically switches to generator or shore power when available, and automatically charges the house batteries at as much as 100 amps, depending on the model, and installer's settings. This is a multi stage charge rate, of course. The original Heart design is now made by Xantrex, and they will service the older Heart units. Vanner also makes a similar type inverter, superior in my opinion to all others, but priced out of my comfort zone!
05-26-2018, 03:18 PM
Citrus County, Fl.
Hmm
99 Terry 31G
05-26-2018, 03:34 PM
Lowe's voltage is bad for AC, draws more amps - heat. Many campgrounds don't balance their 50 amp service, using same for 30 amp. Autotransformer good resort to satisfy AC.
DJsFolly
05-26-2018, 03:44 PM
I’d never camp without my Autoformer and PI EMS.
2019 Jayco Greyhawk 29MV
2019 F-150 3.5 EB SCREW Max Tow - 1797 payload
