Originally Posted by marinerjoe
I’m confused. Why would 50 amp service require larger wire than 30 amp service. I’d think it would be the other way around. Why? Because 30 amp service is being provided on a single 30 amp hot leg, when 50 amp service is coming in on two 25 amp legs. The only wire that would need to be bigger is the neutral to handle both of the hot legs.
I’m not an electrical engineer (my brother is), but I stayed in a Holiday Inn Express not long ago. [emoji6]
Have your brother explain "ohm's law". ( oh, wait, he's an engineer. Better ask an electrician)
30 amp service is 30amps
120 volts #10 cu wire/8 alm.
50 amps is 50amps
240 vots # 6 cu/4 alm
You get 2- 50 amp legs, not 2- 25 amp legs.
It is 240 volts at the pedestal. When it gets to your trailer it is distributed in such a way that you cannot access the 240 volts only 120 volts each leg L1- 50 amps 120 volts. L2- 50 amps 120 volts.
you will hear some say "That's 100 amps" 120 volts. Technicly the neutral should be bigger than the hots but that's for another forum.
Them Holiday will get you in trouble every time
