Old 11-15-2015, 08:51 PM   #121
Tom48's Avatar
Originally Posted by CharlieS3 View Post
Good Questions.
Adding the last two panels was really a no-brainer. .... I made it that big just because I wanted it that way.
I love it All I can say is WOW and JEALOUS.
Tom
Tom48 is offline   Reply With Quote
Old 11-16-2015, 05:42 AM   #122
I have a pretty massive solar system on my Coachmen 380DS. For Batteries, I modified the battery holddowns to install 4 L16 Sun-Extender AGM batteries at 125 pounds each. I have added 6 of the Kyocera 140 Watt panels on the roof (2 more since the pic) giving me a whopping 840 Watts of power. This produces about 40 amps an hour in full sunlight. Per my Victron (highly recommended) we use about 125 amps a day. That includes making coffee in the morning, running the microwave at night, watching TV, and also running my CPAP. LED lights make a difference. For wet batteries, Trojans have a great reputation. Whether you go 6 volt in series or 12 in parallel, or some combination thereof, is not really relevant and will produce pretty much the same storage capacity either way. Just stuff the biggest batteries that you can into the available space and get the best you can afford. Deep Cycle of course.
While you can go portable, its a pretty big pain to setup every time. We look for sites that give minimal tree coverage, but you can't always avoid it. Its just the way it is. Larger capacity means I can go with less sunlight. If going solar, go with paralleling your panels rather than series connection, along with an MMPT controller. In series, if one panel gets shaded, all panels go down. In parallel, only the shade panel is lost. The MPPT controller will max your output. Less voltage may mean that you need bigger cables. Its all a tradeoff, but shading is almost always an issue and I went with the approach that minimizes that effect.
The Victron is a great unit. It tells you your current draw, lets you cut things on and off to see what is drawing heavily, lets you know your state of charge and your rate of re-charge. Lots of fun for a numbers oriented guy like me.
Good Luck with whatever you decide!
Charlie
Thanks for the advice.
Sounds like you have a great system. I'm planning to order the Victron monitor this month barring unexpected expenses.
Due to our tight finances we have to go piece by piece with this thing. We have also decided that Santa will give us at least two 100 watt solar panels and a controller that's large enough to add a third panel in the future.
Our dealer informed us that installing panels on the roof of our brand new trailer would void the manufacturer's roof warranty. We'll buy the kit, use the panels as portable units for now and when the warrantee expires we'll mount them properly.
One question, one of the kits I'm looking at comes with a choice of 12 or 10 aug cable. If we go with this kit, I'd go with the 10 gauge upgrade but is that a large enough cable or should I order 8 awg cab
brooklyncowgirl is offline   Reply With Quote
Old 11-16-2015, 06:27 AM   #123
Charlie
Thanks, sounds like you have a great system. We'll be ordering the Victron monitor this month.
We just took our first trip with the two 70 AH batteries and the LED lights spending four days at Assateague National Seashore. Using my little hand held monitor it looked like barely drew the batteries down the first night but on our second night out DH left the outside light--one of the only incandescent lights we still have son all night--he was being kind, I was coming back from walking the dog--of course I didn't notice that the light was on so he's not solely to blame. That drew the batteries down to a little over 50% so we had to haul out the generator. We apparently did not run the generator long enough to fully charge the batteries so we had to run it again the next morning.
The good news is that if we're careful, we can keep the lights on, and even use the furnace a little at night and in the morning without depleting the batteries too much. We really want those solar panels even more now.
Old 11-16-2015, 09:59 AM   #124
Wire size in a solar system can make a significant difference. The main reason installers will use series rather than parallel connections is that the voltage drop is less significant with a higher voltage. However, the loss is much greater (possible total) if any of the panels becomes even partly shaded. Partial shading can take out the entire panel's production, or series string, not just the shaded percentage.
I installed my system using 8 gauge wire. It was only a little more expensive in the overall scheme of things. But, I also tend to overbuild and I chose a parallel installation. If your system is going to be portable, you will want to use a flexible stranded cable, not a solid cable. Portable systems can give you better access to sunlight, but at the cost of added cable length. A larger gauge will help reduce any loss. 10 gauge for sure. 8 gauge won't hurt but will be bulkier and heavier. 10 is probably fine, even 12 if the total output is small, but you really need to run the numbers.
You can calculate the loss here
Voltage Drop Calculator
Charlie
[SIGPIC]
2005 Coachmen Sportscoach Encore 380DS
2014 Jeep Wrangler Rubicon Unlimited
CharlieS3 is offline   Reply With Quote
Old 11-16-2015, 05:49 PM   #125
Thanks, this is an education for sure.
Old 12-01-2015, 03:33 PM   #126
Update. I just ordered my Victron monitor. Got a good deal at $158.10 with free shipping.
Old 12-06-2015, 09:28 AM   #127
Kenny kustom's Avatar
http://www.balqon.com/store-2/#!/12-...egory=12286436
9kw would be 900ah??
Really?
2016 Sabre 36QBOK
2015 Ram 3500 CUMMINS
2017 Dynamax Isata 4
Old 12-06-2015, 09:54 AM   #128
camaraderie's Avatar
Originally Posted by Kenny kustom View Post
Balqon Electric Vehicle Manufacturer
Really?
2016 Sabre 36QBOK
NO...9000 watt/hours @ 12V is 750 amp hours. Of course there is no mention of the discharge rate to acheive this figure or the composition of the battery which might be lithium ion. Given the weight ...if it WERE a lead acid battery...you'd probably be looking at 4-500 amp hours @ the 20 hour rate. Maybe 750amps using the reserve capacity rating system.
It's all speculation but given the pricing I'm betting lithium ion electric car battery since the charge/discharge amp rates are so high. For when your Prius gives up the ghost.
________
Cam
2015 Georgetown 280DS
2014 Vespa LX150 2014 StellaAuto 125
camaraderie is offline   Reply With Quote
Old 12-06-2015, 09:56 AM   #129
Yes. They are lithium
2016 Sabre 36QBOK
Old 12-12-2015, 05:19 PM   #130
In installed my Victron monitor today. If anyone's concerned about buying one, it's easy to install even by someone whose electronics experience is limited to replacing light switches and installing bulbs and fuses on cars. Our next step will be to see what each appliance draws and get a real idea of what sort of power we are using. By the way, Santa will be delivering the first stage of our solar system next week. I'm starting with a 100 watt panel with a 30 amp controller. I'm guessing we will need one or two more panels but that can wait for now.
battery, upgrade
