Old 09-21-2015, 12:39 PM   #11
I 2nd Turbs. Best bang for the buck are 2 Interstate SRM 24 batteries. About a 20% premium over Walmart batteries, but well worth the difference. Go by the Interstate Battery outlet and pick one up. Compare the weight to the other suppliers. Weight difference is in the lead, and lead is battery life.
RubberNail is offline   Reply With Quote
Old 09-21-2015, 12:45 PM   #12
batteries
I have used 6 volt systems for the last three trailers (10 years) and have been very happy. I think it is a matter of preference, if you can get an equivalent number of amp hours. that is the true measure of how much power you have to run things.
Adding solar is a sound idea. We have a cheap set of two panels, that make around 19 volts, running though a controller, that keeps it at 14 volts, and keeps the batteries well charged. They aren't mounted, so I just put them on top of the rig when I park and put them back in the box when we leave. I rarely run the generator, and we boondock for up to a month at a time (archery elk season in Oregon). The genny only runs if there is a real cold front for several days, or if we need to run the water heater or A/C.
Good luck.
hankpac is offline   Reply With Quote
Old 09-21-2015, 12:59 PM   #13
Originally Posted by Gregg Willow View Post
If you do not have room for two 6v's or want to stay in the 12v world the Trojan T1275 has been a great battery for me. It is 12v, 150ah @ 20 hr rate and is heavy (82lbs). It has thick plates like the 6v's. I switched over to all LED lighting when I first got my camper and can go for about 4 days with conservative use before needing a charge.
T-1275 | Trojan Battery Company
Thanks, do you use one or two of these batteries. A single battery at 150 AH would be about double my single 24 group battery's capacity.
brooklyncowgirl is offline   Reply With Quote
Old 09-21-2015, 01:23 PM   #14
Originally Posted by TURBS View Post
I have had and used dual interstate srm24 batteries for 5 years now with great success.
TURBS
08 duramax tuned n modded
2011 32bhok Sabre
2015 camping "27 nights"
Thanks for the input. I looked on the Interstate web site and didn't see the amp hour rating.
Old 09-21-2015, 01:29 PM   #15
remember that you only really get half that amount of Amp hours on a 12 volt battery
2015 Ram 2500 4x4 6.4l with 2015 Sandpiper 25RLS
Wife, myself and 2 furry kids
Mountndream is offline   Reply With Quote
Old 09-21-2015, 01:49 PM   #16
That one is 84 ah, so you have approx 42 usable amp hours.
2007 Surveyor SV230
- 200 Watts Solar/MPPT Controller - 230 AH Battery Bank - 600 watt PSW Inverter - (2) 2000 watt Inverter Generators - LED Lighting
Boon Docking 99% of the time.
2009 F150 - 5.4 Litre - Tow Package
boondocking is offline   Reply With Quote
Old 09-21-2015, 06:35 PM   #17
Thanks guys. I Appreciate the input. Looks like size wise We're limited to 2 6 volt, 2 group 24 12 volt or one bigger 12 volt. That and the fact that we are cash strapped newbies and therefore need moron proof DIY. 6 volt sounds good and I've seen the wiring diagrams it doesn't look too complicated but what happens if we screw it up?
Old 09-21-2015, 07:15 PM   #18
Gregg Willow's Avatar
Yes, I just use one. It is the capacity of my a-frame at the hitch. That is the reason why I went with one battery but needed some oomph.
You are a smart newbie by creating a thread like this and being informed. Best of luck with your choice.
2016 Ford F-150 4x4 Supercab XLT EcoBoost
2012 Salem Cruise Lite 221RBXL, Andersen No Sway WDH, (2) Honda EU2000i's
Gregg Willow is offline   Reply With Quote
Old 09-21-2015, 07:30 PM   #19
A good read here...
What does “20 Amp Hr rate” mean?
Old 09-21-2015, 07:47 PM   #20
yvesm's Avatar
I use 2 Trojan 24 tmx deep cycle batteries. Dual purpose batteries are not as good as a battery made for deep discharge.
2013 Prime Time 230 FBS
Days camped in 2013: April to November
Days camped in 2014...about 40
Days camped in 2015...more than 2014!!
yvesm is offline   Reply With Quote
battery, upgrade
