Old 09-22-2015, 06:06 AM   #31
Originally Posted by Gregg Willow View Post
Yes, I just use one. It is the capacity of my a-frame at the hitch. That is the reason why I went with one battery but needed some oomph.
You are a smart newbie by creating a thread like this and being informed. Best of luck with your choice.
Thanks, I don't know if I'm smart but I am cheap. I hate spending money on something that's not going to work and then having to spend more money to correct the original bad decision. This is all new to us. Put my husband and me in a tent and we're pretty competent campers--Eagle Scout and First Class Girl Scout. Put us in an RV and we're--well--newbies.
brooklyncowgirl is offline   Reply With Quote
Old 09-22-2015, 06:22 AM   #32
TURBS's Avatar
Originally Posted by Blackhat6mike View Post
You shouldn't HAVE to upgrade your converter unless you just want to add more charging amps. If you have a WFCO converter, you may want to give thought to a Progressive converter around 60 amps. I've had two WFCO 55 amp units go south on me in three years. Progressive is a much better unit and they go up to 90 amps.
Going more then 70 amp requires a dedicated 20 amp receptacle.
TURBS
08 duramax tuned n modded
2011 32bhok Sabre
2015 camping "27 nights"
Old 09-22-2015, 08:04 AM   #33
If you really want to save weight look in to Lithium. Yes, they are expensive, but the life cycle is double that of SLA or AGM, no maintenance, flat discharge curve. Best decision I've made for my bass boat. Once the Sears PM1 on my TT dies I'll be going lithium.
Riccochet is offline   Reply With Quote
Old 09-22-2015, 10:10 AM   #34
camaraderie's Avatar
If you only have room for two...then QUality true deep cycle 12V's are the way to go. If you lose a 6V battery due to defect or short...you are dead in the water with a pair. With 12V batts...each stands alone as a power source. Trojan or Deka would be my recommendations as makers. Group 31 is your best bet if it fits...followed by group 27 and then group 24. You should also take a look on the trojan site at some of the NON standard size 12V batts they carry that pack a lot of amp hours if you have some extra height available.
With TWO 12V batts you'll have around 200 amp hours (if you use group 31 or 27) which will give you 100 usable amp hours a day befor you need to recharge. Your charger should be rated at 20% of capacity to quickly charge...so a 40-50amp charger is ideal. MORE will get you NOTHING as wet cells cannot accept more. Less will take longer and you'll spend it on generator gas.
Solar will give you 1/4 of rated wattage in a sunny, unshaded location in amp hours per day ON AVERAGE. So 200 wAtts of pAnels should provide around 50 amp hours a day. 400 watts would be good to allow full recharge from 50% depletion on a pair of batteries as above.
Hope this helps.
________
Cam
2015 Georgetown 280DS
2014 Vespa LX150 2014 StellaAuto 125
camaraderie is offline   Reply With Quote
Old 09-22-2015, 11:57 AM   #35
If 1 12 v fails it will drain the other battery and you won't know which on is bad and should be replaced in pairs but if you have 2 6 volt batteries in series if 1 cell should go bad you get 11 v and can be measured and replace 1 at a time instead of in pairs. The lower cell wont drain the other battery. I had to replace my 2 12v ones every 2 years or so, but my 2 6v batteries lasted for 2 trailers and is still going strong.
NorSnrub is offline   Reply With Quote
Old 09-22-2015, 12:06 PM   #36
Hope this helps.
Thanks, looking at the size of my battery bracket I should be able to fit 2 6volt or 2 group 24 12 volt battery boxes--anything larger and I'm limited to one. Height is not a problem but weight is. I'll check out some of those non-standard 12 volts from Trojan you mentioned. The Trojan J185H-AC looked good at 225 AH but at 14" high I'd need a special sort of battery box for it. Might be topheavy too. At any rate, the search continues.
Old 09-22-2015, 08:00 PM   #37
Tom48's Avatar
Originally Posted by Kenny kustom View Post
When going to the 6volt route...
At what point do you have to upgrade the converter / charger?
4x6v?
2008 F350 CCSB V10
2016 Sabre 36QBOK
Probably not even then unless you want them to charge your 4 6s alot faster like on you Generator for shorter time.
The Solar charger limit is how much solar you plan to push through it. A Thirty Amp Solar charger will probably handle 4 100 watt panels if they are flat on the roof. If you are pointing them at the sun on legs I suspect on a hot day you might push the 30 amps but that is why there are fuses on everything I do. Normally on my 2 100 watt panels laying flat on the roof I get a max of about 13 amps at high noon if the batteries are low. If I was going to 400 watts, it might be time to look in to a bigger charge controller but the 200 watts keep my 3 Group 24 size batts fat and happy unless we get crazy with the the Inverter powering the microwave. But with a little restraint it has never been a problem. We have gone 4 or 5 days with no need of generator or shore power. (Full disclosure we are normally in sunny California)
Tom48 is offline   Reply With Quote
Old 09-22-2015, 08:50 PM   #38
Blackhat6mike's Avatar
Originally Posted by boondocking View Post
I could be wrong, but I have never heard of a Group 31 battery having a 200 ah rating, usually they are around 100-120 ah.
It has it right on top of the battery and it's straight from the horses mouth [Interstate Dealer] 190 amp hours.
Aviator Wright Flyer #1919
Army Pathfinder Vietnam, 3 tours
DAV, MOPH, VFW, NRA, 1stCav. ABN
Blackhat6mike is offline   Reply With Quote
Old 09-22-2015, 08:56 PM   #39
TURBS
2011 32bhok Sabre
I wasn't suggesting him go to a 90 amp converter, just that Progressive has a lot of models above 30 amps, where as I don't think WFCO goes more than 55 amp. I may be wrong on that, but that's the biggest I've seen.
Old 09-22-2015, 09:04 PM   #40
4x6v?
2008 F350 CCSB V10
2016 Sabre 36QBOK
KK... if you are plugged in most of the time, you're charging all the time so the size of the charger hardly matters...but 10% of a/h capacity is usually the minimum specified. That would mean a pair of 6V would needabout 20amps and a bank of 4 would need 40amps.
If you are boondockinng using a generator...you'd want to double those numbers to reduce charging time daily...by roughly half, and the upgrade will pay for itself in less gas used, and less maintenance & wear & tear on the genny.
Boondocking with Solar is a bit more difficult as you need to size your panels to your daily amp hour use. (i.e. 4x your daily amp hours used in solar watts) if you want to be totally green. Installing a REaL battery monitor and seeing your actual daily amp/hours use before purchasing a set of panels is a good way to determine what you need.
________
Cam
battery, upgrade
