Old 09-22-2015, 09:14 PM   #41
Kenny kustom's Avatar
Good info!!
2008 F350 CCSB V10
2016 Sabre 36QBOK
2017 Dynamax Isata 4
Old 09-22-2015, 09:37 PM   #42
John McClain's Avatar
Just keep in mind two 6 volt batteries rated 225AH a piece = 225 AH total
two 12 volt batteries rated at 150 AH a piece = 300 AH hours total
one 12 volt goes bad you have 150 AH. one 6 volt goes bad you have nothing.
15 years ago the only deep cell batts where 6 volt only. now they make lots of true deep cycle 12 volt batteries . My old toy hauler I ran 3 . 12 volt street sweeper batteries made by US battery in my opinion they are better than trojan 160 AH x3 = 480 AH
F-250 . stealth 3210 solar pannels, fantastic fans. and life line batteries
John McClain is offline   Reply With Quote
Old 09-22-2015, 09:43 PM   #43
Originally Posted by Blackhat6mike View Post
It has it right on top of the battery and it's straight from the horses mouth [Interstate Dealer] 190 amp hours.
Could you give me the model # of that battery. I would like to get a couple of them to replace my two 6v. I would really like to have 380 AH with two batterys that would fit in my box.
2007 Surveyor SV230
- 200 Watts Solar/MPPT Controller - 230 AH Battery Bank - 600 watt PSW Inverter - (2) 2000 watt Inverter Generators - LED Lighting
Boon Docking 99% of the time.
2009 F150 - 5.4 Litre - Tow Package
boondocking is offline   Reply With Quote
Old 09-22-2015, 09:46 PM   #44
Blackhat6mike's Avatar
I couldn't remember the exact model of my batteries that power my solar array, so I had to go and open up the battery compartment and take a look [CRS]. I have 4 Interstate Group 31-AGM7 batteries. They are rated at 190 amp hrs and have a three year warranty. I think I paid $275 each. That's 760 amp hrs and I don't even use the converter anymore. The 600 watt panels keep them topped off.
Aviator Wright Flyer #1919
Army Pathfinder Vietnam, 3 tours
DAV, MOPH, VFW, NRA, 1stCav. ABN
Blackhat6mike is offline   Reply With Quote
Old 09-23-2015, 12:17 AM   #45
camaraderie's Avatar
THERE IS NO SUCH THING as a group 31 wet cell battery with 190 amp hours at the 20amp hour rating. You are being shown the RESERVE Capacity amp hours. This is a much different rating...apples and oranges.
Look https://www.interstatebatteries.com/...o/marine_f.asp
and you will see NO 20 hour rating on many of their so called deep cycle batts. But you will see it on their optima and 6v batts.
Don't be fooled.
________
Cam
2015 Georgetown 280DS
2014 Vespa LX150 2014 StellaAuto 125
camaraderie is offline   Reply With Quote
Old 09-23-2015, 12:51 AM   #46
Thank you for the info Blackhat.
I went on the net to see where I could purchase these batterys (Group 31-AGM7) and according to the Interstatedealers website they are rated at 96 amp hour.
http://www.interstatedealers.com/pdf/201080.pdf
Another Interstate site says 190 reserve minutes.
2007 Surveyor SV230
Old 09-23-2015, 07:48 AM   #47
If you want the best G31 AGM battery check out the Sears PM1. Pretty much the gold standard in the marine world AH, RC and longevity.
You won't find G31 AGM's with much better specs.
Riccochet is offline   Reply With Quote
Old 09-23-2015, 07:58 AM   #48
banda's Avatar
Originally Posted by Gregg Willow View Post
If you do not have room for two 6v's or want to stay in the 12v world the Trojan T1275 has been a great battery for me. It is 12v, 150ah @ 20 hr rate and is heavy (82lbs). It has thick plates like the 6v's. I switched over to all LED lighting when I first got my camper and can go for about 4 days with conservative use before needing a charge.
T-1275 | Trojan Battery Company
Do you remember the price on that battery?
banda is online now   Reply With Quote
Old 09-23-2015, 08:07 PM   #49
Interstate Battery site is not user friendly. Someone said I was being fooled. Well, so is my boat, my golf cart and my TT. The add says they can take 80% discharge for 400 times. I do believe that qualifies them as "Deep Cycle". AND they have a three year warrantee.
Interstate Batteries Results Page - D replacement battery
Old 09-23-2015, 08:10 PM   #50
TURBS's Avatar
Originally Posted by Riccochet View Post
If you really want to save weight look in to Lithium. Yes, they are expensive, but the life cycle is double that of SLA or AGM, no maintenance, flat discharge curve. Best decision I've made for my bass boat. Once the Sears PM1 on my TT dies I'll be going lithium.
10 - 12 years
TURBS
08 duramax tuned n modded
2011 32bhok Sabre
2015 camping "27 nights"
battery, upgrade
