Old 10-15-2015, 06:22 PM   #11
thanks
were can i get a GFCI tester
cpfdmiller is offline   Reply With Quote
Old 10-15-2015, 06:26 PM   #12
Home Depot, lowes or any big box store. Just plugs in and has a test button.
2016 Flagstaff 23lb
Toddupton is offline   Reply With Quote
Old 10-15-2015, 06:26 PM   #13
Originally Posted by cpfdmiller View Post
thanks
Walmart
Ge 50957 110125V GFCI Tester - Walmart.com
2011 Traverse LT, 3.6L, FWD
rockfordroo is online now   Reply With Quote
Old 10-15-2015, 06:28 PM   #14
Herk7769's Avatar
Originally Posted by OldCoot View Post
Dual posts on this problem. Just super glue the pc back on.
Duplicate fixed and moved to electrical.
If you have the piece, glue it on as OC stated as the faceplate will hide the crack.
If not put an "old work" outlet box (use a box cutter to make the hole square) in and use a standard Decura duplex outlet and cover.
http://www.homedepot.com/p/Leviton-D...210757&cj=true
Carlon 1-Gang 14 cu. in. Old Work Box-B114RB - The Home Depot
Leviton Decora 1 Gang Midway Nylon Wall Plate - White-R62-0PJ26-00W - The Home Depot
NOTE - YOU DO NOT NEED A GFCI on that outlet. it is DOWNSTREAM from the controlling GFCI outlet and therefore just needs the sticker.
You can use a label maker or a magic marker.
PS - Sorry used link for 10 pak - replaced with the single one.
HAM CALLSIGN - KC3FFW
Old 10-15-2015, 06:29 PM   #15
I replace mine with a regular gfi outlet, that has screws. I feel these are safer than push on wires that shown in the picture.
2014 cedar creek 36ckts
2014 Chevy 3500 1 ton crew cab 4x4 long bed.
cfiowa is offline   Reply With Quote
Old 10-15-2015, 06:31 PM   #16
Ford Idaho's Avatar
thanks
I bought this one.
Electrical Receptacle Tester with GFCI Diagnosis
