Old 10-15-2015, 05:50 PM   #1
plug out help!!!!
i have been looking every were and no one seems to know were i can get this outlet. it out of my EVO 2014 travel trailer i need to replace this due to a is broken on one side. Please Please help
also any help with any thing i need to know on replacing this outlet would be great never seen one like this before???Click image for larger version
cpfdmiller is offline   Reply With Quote
Old 10-15-2015, 05:52 PM   #2
Super glue it back together.
Old 10-15-2015, 05:57 PM   #3
plug out let help
im trying to find this outlet any help would be great cant find any were really want to get this replaced.
Also any help on the wiring would be great never seen one like this before. this is out of my EVO the out let next to the sink in the kitchen.Click image for larger version
Old 10-15-2015, 05:59 PM   #4
Dual posts on this problem. Just super glue the pc back on.
Old 10-15-2015, 06:01 PM   #5
Iwannacamp's Avatar
Any wholesale electrical place...maybe even Home Depot or lowes.
Name:	ImageUploadedByForest River Forums1444950092.728067.jpg
2017 Puma 297RLSS
Old 10-15-2015, 06:03 PM   #6
Just get a regular outlet from Home Depot and a shallow remodel box. I hate insulation displacement outlets anyway.
2019.5 Rockwood 2509S
Toddupton is offline   Reply With Quote
Old 10-15-2015, 06:04 PM   #7
Any model number embossed on the box, cover. Search GFIC or GFI with a model number if found. Just sayin'
Old 10-15-2015, 06:05 PM   #8
mark0224's Avatar
Amazon has them http://www.amazon.com/RV-Designer-Co...ords=rv+outlet
Think about things before you do them make life easier not harder.
mark0224 is offline   Reply With Quote
Old 10-15-2015, 06:09 PM   #9
looking at the back of the out let looks i need the same one to make it work with the rest that are in line correct? im not sure what brand this is or were to look for one i tried home depot, lowes, granger.
Old 10-15-2015, 06:17 PM   #10
Brand does not matter. It is just daisy chained from a GFCI and will still function. After you install it just plug in a GFCI outlet tester and check it.
Old 10-15-2015, 06:22 PM   #11
thanks
were can i get a GFCI tester
Old 10-15-2015, 06:26 PM   #12
Home Depot, lowes or any big box store. Just plugs in and has a test button.
Old 10-15-2015, 06:26 PM   #13
Originally Posted by cpfdmiller View Post
thanks
Walmart
Ge 50957 110125V GFCI Tester - Walmart.com
2011 Traverse LT, 3.6L, FWD
Old 10-15-2015, 06:28 PM   #14
Herk7769's Avatar
Duplicate fixed and moved to electrical.
If you have the piece, glue it on as OC stated as the faceplate will hide the crack.
If not put an "old work" outlet box (use a box cutter to make the hole square) in and use a standard Decura duplex outlet and cover.
http://www.homedepot.com/p/Leviton-D...210757&cj=true
Carlon 1-Gang 14 cu. in. Old Work Box-B114RB - The Home Depot
Leviton Decora 1 Gang Midway Nylon Wall Plate - White-R62-0PJ26-00W - The Home Depot
NOTE - YOU DO NOT NEED A GFCI on that outlet. it is DOWNSTREAM from the controlling GFCI outlet and therefore just needs the sticker.
You can use a label maker or a magic marker.
PS - Sorry used link for 10 pak - replaced with the single one.
Lou & Freya the wonder dog
2019 Flagstaff 8529FL
Old 10-15-2015, 06:29 PM   #15
I replace mine with a regular gfi outlet, that has screws. I feel these are safer than push on wires that shown in the picture.
2014 cedar creek 36ckts
2014 Chevy 3500 1 ton crew cab 4x4 long bed.
cfiowa is offline   Reply With Quote
Old 10-15-2015, 06:31 PM   #16
Ford Idaho's Avatar
thanks
I bought this one.
Electrical Receptacle Tester with GFCI Diagnosis
