09-14-2019, 02:56 PM
Plug receptacle melted
Hey guys club this out smelled smoke in trailer after being gone for 5 hours and find the end of my cord and trailer side plug melted.
09-14-2019, 03:02 PM
Part-Time Campground Host
What the heck did you have plugged in?
That is some serious amp draw.
What cords are you using?
Any adapters in the loop?
A pic would help.
Craig & Cath
Days camped since 2015(retirement): 1680
09-14-2019, 03:03 PM
I can’t remember how to post. 25 foot stock cord only ac
09-14-2019, 03:08 PM
Is the power still working?
Have you done any modifications?
Did it work on prior trips?
What was plugged in inside the camper?
30 or 50 amp?
Did you blow any breakers in the camper or pedestal?
Craig & Cath
09-14-2019, 03:12 PM
Here’s a pic
Pic
09-14-2019, 03:13 PM
If it's a 30 amp, did you twist it to the right, when you plugged it into the trailer outlet?
Many fail to to this, which causes a poor connection.
Here
09-14-2019, 03:14 PM
No mods nothing bone stock 2014 worked till now 831bhds
09-14-2019, 03:15 PM
Yes it was locked in and collar tightened
09-14-2019, 03:34 PM
Makes me want to unplug the power when ever we leave the trailer for any length of time.
John & Donna: Retired
Trudi: My Partner in Crime. R.I.P. 6/19
2018 Silverado Double Cab Z71
2018 FR Flagstaff Micro Lite 21DS
09-14-2019, 03:35 PM
Maybe this time but not in the past. That is caused by loose connections. You must 1/4 turn every time and install locking ring. Obviously you need to replace both haves
09-14-2019, 03:45 PM
Yep, may be a warm night
09-14-2019, 05:30 PM
May be a loose connection on the other side of the plug.
09-14-2019, 06:02 PM
If it has worked and it was connected properly I am also thinking loose connection on a terminal. This is not common but has happened before.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
09-15-2019, 04:45 PM
Mine did the same thing. I replaced it and cut the failed one apart. What I found was the crimp where the wire is attached to the plug was loose. This created a lot resistance which is what melted the plug. After I replaced the end I never had that problem again.
2012 Georgetown XL 350TS, Hellwig front/rear sway bars, Sumo Springs, Blue OX True Center steering damper
2013 Ford Explorer LTD toad, Roadmaster Stowmaster 5000, VIP><Tow Brake
Better to have a bad day of camping than a good day at work!
