Old 03-12-2016, 06:44 PM   #11
Ohmed out the wires behind panel, there was contenuity, thats why none of this makes sense.
dfenendael is offline   Reply With Quote
Old 03-12-2016, 07:21 PM   #12
Head Rambler
So you have power on the shore power cable up to where it enters the RV, but not to the distribution panel? Is that correct?
Does the cable plug into the RV? If so you may have a bad connection in the plug mounted in the RV.
Gotta go campin!
Old 03-12-2016, 07:29 PM   #13
hammer55's Avatar
double check the neutral, there is usually a neutral problem when you have power (voltage) and still nothing works, check all connections and terminals, just a thought
Mark & Annie
2014 COACHMEN PURSUIT 27 KB
Modesto, Central California
hammer55 is offline   Reply With Quote
Old 03-12-2016, 07:32 PM   #14
Yes correct we have power on the shoreline up to where it enters the rv, but not to the distribution panel. Yes the cable plugs in to the rv. That would be great if thats the problem, that would be an easy fix.
Old 03-12-2016, 07:39 PM   #15
We were thinking about a neutral problem also, but geez where to start on that..... just don't understand how nothing wrong all last summer, we winterized it. Then today, nice day, so decide to open it up to do a little cleaning, plug it in & nothing. Just irratating.
Old 03-12-2016, 10:40 PM   #16
GLCM Warrior
Lefty59's Avatar
If you are certain you have power at the cord end where it plugs into the outside of the RV and you've ohmed out the wiring from there to the back of the distribution panel then I'd suspect a bad main breaker might be the problem. Maybe you can remove the breaker and do a continuity test on the breaker itself?
Might also suggest using an outlet checker to see if a wiring fault shows up in any of the circuitry. I'd turn all the breakers off except the main and one other and then work my way through testing each circuit separately.
Best wishes in finding the problem!
2014 Wildcat 312QBX
2014 Ford F350 SD 4X4 CC LB 6.7L PSD
Bob & Debbie, USAF Retired
Lefty59 is offline   Reply With Quote
Old 03-12-2016, 11:22 PM   #17
B and B's Avatar
Unplug the trailer, check the wiring behind the inlet. My neutral was loose from the factory. Tighten all connections.
2017 Heartland Bighorn 3575 Elite with Reese Sidewinder
2016 Ford F 350 SD PS 6.7 SRW Crew Pucks and Reese 18 K Elite
2013 Rockwood 8289WS 2012 Rockwood 2703 SS TT 2007 Golden Falcon 38FLA PM 1983 Corsair 21RB
2015 Ford F250 PS '13 F150 3.5 Eco '09 F150 5.4 l 1987 Merc Grand Marq 1982 Ford E250 CW
Old 03-13-2016, 03:33 AM   #18
Thanks everyone! Will try again in the morning to solve it!
Old 03-13-2016, 06:20 AM   #19
I couldn't tell from your posts but make sure that you disconnect your battery first (if it's charged up and connected) before you start using fingers and tools on the service side of your panel. The 120V might be dead but the 12V probably isn't
2010 Wildwood XLite 26BHXL
2013 Ram Outdoorsman 5.7l
Ontherock is offline   Reply With Quote
Old 03-13-2016, 08:50 AM   #20
hammer55's Avatar
is there a disconnect, from the receptacle a junction box, open the panel check terminals, it is just slow and steady elimination,
Mark & Annie
camper, power
