Old 07-01-2012, 11:55 PM   #1
Plugged my 30 amp into 220 VAC - help
Did I damage the wfco 8900 converter after plugging it into a 240 30 amp outlet? When I plugged it in, the outlet sparked and I heard a pop inside where the converter is. I reset all breakers and now When I plug into the 110 outlet on the other side of the house (where I used to plug into to charge batteries) the lights are dim (battery very low) and no hum from the converter.
frankcarpi is offline   Reply With Quote
Old 07-02-2012, 11:08 AM   #2
Ouch. More than likely it is toast. With some luck from the electrical gods your microwave might still be good and other things that were plugged in. Good luck, you are going to need it.
RedRollingRoadblock is offline   Reply With Quote
Old 07-02-2012, 12:42 PM   #3
TURBS's Avatar
Not uncommon for this to happen to those unwise to rv power which is only 110v
Things u may have ruined including converter.
Microwave
Radio/entertainment center
Tv's
Fridge
You need to check all fuses and circuit breaker with a volt meter.
Old 07-02-2012, 04:47 PM   #4
How is that even possible ? 240 Vac outlets use a completely different receptacle layout than a 110Vac outlet .
...VTX-Al
VTX Al is offline   Reply With Quote
Old 07-02-2012, 04:58 PM   #5
Too old to be too smart
SpringerPop's Avatar
Originally Posted by VTX Al View Post
How is that even possible ? 240 Vac outlets use a completely different receptacle layout than a 110Vac outlet . l
That's a very good question, the answer to which I'd like to hear!
Pop
2005 Terry 250RKS, perfect for the two of us and the pups.
It recently replaced our Flagstaff 21FB (which we still have)
2000 F-350 7.3L CC/LB 4WD Lariat 3.73's
SpringerPop is offline   Reply With Quote
Old 07-02-2012, 06:05 PM   #6
Originally Posted by SpringerPop View Post
That's a very good question, the answer to which I'd like to hear! Pop
RV Electric click the 30 amp Service link on the upper left.
Old 07-02-2012, 07:52 PM   #7
TURBS's Avatar
I'm guessing the op or his "electrician"
Wired it with out the knowledge of what they were doing.
