Old 07-30-2015, 02:34 PM   #11
Georgia Frog Rally 2018
aceinspp's Avatar
If your going to do it do it right. I had my electrician install 20 amp breaker than he ran a wire to a junction box to side of house and wired in the 30amp connector so now I just take my 50amp/30amp and plug in. You only need to run one air any way. Later RJD
2018 Dodge Ram 2500 6.4 3:73 gearing.
Days camped in 2016 58
Days camped 2017 62
Days camped 2018 18
Old 07-30-2015, 02:41 PM   #12
Herk7769's Avatar
Originally Posted by asquared View Post
Should I use my surge protector for this?
We can have a long talk about this at the rally.
HAM CALLSIGN - KC3FFW
Old 07-30-2015, 02:57 PM   #13
Fulltime family RVer
I have a 50 amp trailer. My house has normal house outlets outside. Read not wired for the trailer and not a dryer outlet either. Can I plug into a 50/30 amp adapter and then to a 30/15 amp adapter and plug directly into a regular house outlet to run fridge and charge the battery? If yes can I run one of my air conditioners ( I have a 15 btu and a 13 btu a.c.)? If no,how can I plug into house? I have a battery charger but wanted to look at other ideas. Thanks
As mentioned, yes you can.
As for A/C, I used a heavy duty extension cord. It's 50' and costed something like $50-75 from Home Depot. I run my A/C as long as it is the only thing running. Even with my surge protector, it didn't give me low voltage or any warnings doing it.
I personally would ALWAYS use a surge protector if I had one. In fact, that's why I put a hard-wired one in.
Old 07-30-2015, 03:09 PM   #14
chrisbailey13's Avatar
You can run your charger and fridge on a 15amp circuit. you have to be sure your hot water heater doesn't come on or you might trip the GFI if you have one.
But at home depot:
50 amp outlet $28.00
50 amp breaker $10.00
#6 Wire $0.90 per foot
Piece of mind...Pricele$$
and you can run both AC's the Fridge, the charger, and will not need any adaptors
2014 Georgetown XL 352QS
2013-2017 Days Camped-215
chrisbailey13 is offline   Reply With Quote
Old 07-30-2015, 03:37 PM   #15
hrlyguy2's Avatar
I just use direct 50 amp to 110 adapter. Works fine no 50 to 30 to 110
But like others say for fridge and charging
2007.5 Chevy 3500Ltz cc lb Duramax
2010 Sandpiper 345 RET (SOLD)
hrlyguy2 is offline   Reply With Quote
Old 07-30-2015, 05:00 PM   #16
DKRITTER's Avatar
We had an electrician come and do several things to the house for us and one of those was to put a 50AMP plug out by the trailer and we love it.
We on occasion have house guests who stay in the trailer and it sure makes it simple.
DKRITTER is offline   Reply With Quote
50 amp
