Old 07-01-2015, 10:35 AM   #11
Ret E-9 Anchor-clanker
donanddona's Avatar
Have you ever thought what if? Like maybe install a 50amp receptacle and use a adapter? (inexpensive) Just saying......
donanddona is offline   Reply With Quote
Old 07-01-2015, 10:37 AM   #12
jonrjen's Avatar
I think a little differently. I would run enough power to do a 50amp outlet and then use a 50amp to 30amp adapter for plugging in the RV. Because while 30amp service may fit your current needs, what if the next RV comes with 50amp service.
2013 Ford F350 FX4 4x4 PSD
2013 Wildcat 353LS
2015 Day/Nights Camped 5
2014 Day/Nights Camped 29
jonrjen is offline   Reply With Quote
Old 07-01-2015, 10:38 AM   #13
Originally Posted by TURBS View Post
8 ga would probably be better.
TURBS
08 duramax tuned n modded
2011 32bhok Sabre
2015 camping "11 nights"
His deal is for 10-3. But 6ga would be even better.
Old 07-01-2015, 01:07 PM   #14
waiter21's Avatar
I made a 50ft "extension cord" for my 30 amp service. Now that I keep it in the MH, I bet I will never need it. ( We spent a few nights at an RV park where the utility poles were on the wrong side and we had to pull in straight to reach the pole)
I purchased the male and female 30 amp connectors at "Menards". This is similar to Home Depot or Lowes.
2001 Coachmen Mirada (Ford F53 6.8L V10) - Toad 2003 Saturn Vue
It won't do MACH 2, but I can get a sandwich and take a pee.
waiter21 is offline   Reply With Quote
Old 07-01-2015, 01:08 PM   #15
OK - I think I'm gonna go for it. In reviewing inside my head, four factors stick out:
1. the run I'm making is no worse than when I use my regular cord + extension cord at those campground where the pedestal is in the wrong spot.
2. The wire I can get is identical to what is used in RV cords.
3. I can fairly easily control what will be in use at the same time while plugged in at home, so can avoid AC + micro + water heater scenarios.
4. If I ever upgrade to a 50 amp unit, I can either do a 50 to 30 pigtail or upgrade the wiring at that time.
This kind of goes against the always popular "do it right the first time" principle, but then again that principle assumes that you have the necessary funds to "do it right" today when in fact you may only have enough to "do it."
Thanks again for the input and for making me think this through carefully.
And, most importantly, this thread has boosted me over the 100 post mark on FRF. Only 19,389 to go to catch OC.
Brian, Stacy, and the girls (11 and 8)
2011 F-250 CCSB 6.7L PSD 4WD
2013 Solaire 269BHDSK
ProPride Hitch
purduepete97 is offline   Reply With Quote
Old 07-01-2015, 03:06 PM   #16
Dazed & Confused
M&K Hoffman's Avatar
If you run 10/3 cable 60 feet and are drawing 25 amps, (the allowed 80% continuous load) your voltage drop will be right around 3 volts. It is not very often you would be drawing that much current, I say go with the 10/3.
BTW Here is a good plug: 30 Amp Retro Fit Kit
~Mike & Kim~
2014 Rockwood Windjammer 3008W Diamond Package
2012 Toyota Tundra Doublecab 5.7 4WD
M&K Hoffman is offline   Reply With Quote
Old 07-01-2015, 03:23 PM   #17
benagi's Avatar
We have a Minnie Winnie 25 ft that we have plugged in to a regular 110 receptacle with an adapter on the RV plug. We do this a day before leaving for a trip. It runs the A/C fridg, etc when loading our unit. We have since purchased a Forester 3171DS. Will we be able to still use the same 110 receptacle in the garage with a standard 110 adapter on the RV plug, or will we have to add a 30amp receptacle in the garage. I think the 110 wall plug in the garage right now is only a 20 amp. Need to check and make sure when I get home today. Thx, Ben
1968 tent trailer
1985 Jamboree 23 ft
1997 Minnie Winnie 25 Ft
2016 Forester 3171DS (ordered March & arrived June 2015)
benagi is offline   Reply With Quote
Old 07-01-2015, 03:23 PM   #18
Ham Camper's Avatar
I would also say that 60 feet would be a lot safer if #8 wire was used instead of #10. Heavier is always better and safer
Larry W8PO & Lori N8IHJ and Louie the wonder dog
2014 Surveyor Cadet 265RLDS
2015 GMC Denali HD
Ham Camper is offline   Reply With Quote
Old 07-01-2015, 03:25 PM   #19
Captn.Ken's Avatar
I just looked on eBay and they have a couple for as low as $7. Be careful about voltage on plug. I messed up and got a 30 amp but it was for 250 volts and wouldn't fit. Need 30 amp for 125 volt to fit TT inlet.
Captn.Ken is offline   Reply With Quote
Old 07-01-2015, 03:49 PM   #20
SaubleGuy
Go to any electrical supplier to buy twist lock female without ring. 30A3wire
2x on the #8 wire.
Saubleguy is offline   Reply With Quote
