07-01-2015, 03:58 PM
#21
If you do it your way run the largest gauge wire you can. 60 Ft is a long way.
07-01-2015, 04:16 PM
#22
Rodney & Patty
For what it's worth, I ran mine with 4 gauge - had a couple of hundred feet hanging around. If I was just setting it up now however, I would wire it with an RV 50amp plug and use the adapter to the 30amp cord. We all seem to upgrade and most of the newer, bigger stuff is 50amp. The adapter will be a needed expense anyway and wiring it up once is always cheaper than doing it over. If I recall correctly my 30 amp receptacle was about $30 10 years ago when I set mine up.
I also set up an RV sewer drain into my residential septic system. That way my RV really does double as a guest house and if some RV type friends are in the area and want to stop by for a week they can camp in my yard for free with all the conveniences of a nice park, including a concrete pad to park on.
Working because we have to - camping because we want to.
2015 Salem Hemishere 337 BAR
2014 Ram 3500SRW Laramie 6.7 I6
07-01-2015, 06:04 PM
#23
Purchase a 30 amp short cable and use a 30 to 15 amp adapter then a heavy duty extension cord.......I use the same set up only mine is a 50 amp connector on 5er
07-01-2015, 09:01 PM
#24
Good idea to stay plugged in?
Our house came with a gravel RV pad and 30 amp hookup from previous owner. I leave TT plugged in all the time to keep the fridge going and run the lights periodically when we are out there in between trips. Is it bad for fridge from a longevity stand point to run all the time? Is it bad for my battery to stay perpertually charged and never really be used except for a few minutes here and there in between hookups etc?
TV - 2007 Tundra Dbl Cab
2014 Rockwood Roo 25RS
Nights camped 2014-27, 2015-28, 2016-31
Nights camped 2017-16, 2018-6, 2019-10
07-01-2015, 09:23 PM
#25
Yes on the fridge and yes on the constant charge
07-01-2015, 09:51 PM
#26
How sweet of a deal is this cord? Is someone paying you to take it? I'm not going to dig through the 2014 NEC but I'm pretty sure that running cord in a building for a circuit such as this where flexibility of the conductors is not required is a violation. Also, cord generally does not carry the same ampacity as solid copper wiring which in your case would likely be 10-2wg NM-B depending on your local codes. Its always entertaining watching people with the money to sink into an nice RV completely cheap out on setting up the correct electrical circuit to plug the expensive thing into....
2015 Sierra 357TRIP
2012 Ram 2500 CCSB 6.7CTD
07-01-2015, 09:57 PM
#27
B &. The longer you run that cable (100 ft) the more damage over the long run you will cause with small wire. One always has to watch "heavy duty use"
07-01-2015, 10:07 PM
#28
Originally Posted by TURBS
Update... 110 volt
30 Amp | Marinco
B and B
07-02-2015, 06:38 AM
#29
When I made my 50ft extension cord, I bought a 50ft 10/3 welder extension cord on e-bay, cut the ends off and installed RV 30 amp connectors. Cord and connectors, I think I have $75 in it. Now that I carry it in the MH, I'm betting I will never need it. :-)
NOTE - I prefer to carry multi purpose components - I'm thinking about making a couple short adapters that I can plug into this cord and they'll have alligator clips on the ends, This would give me a 50ft long jumper cable. I've needed that a couple times. :-)
2001 Coachmen Mirada (Ford F53 6.8L V10) - Toad 2003 Saturn Vue
It won't do MACH 2, but I can get a sandwich and take a pee.
07-02-2015, 07:00 AM
#30
I don't think I'm "cheaping out". I'll be using the same cord you use at the campground, and roughly the same length you'd use if you have to use an extension on your regular cord (assuming 25' regular cord + 25' extension). It'll be running along the side and end walls of a 100% metal building. To avoid code issues, I may elect to install an RV outlet adjacent to the breaker panel instead of hard wiring the "cord" into the breaker box. Then it'll truly be an extension cord versus a hard-wired installation.
Thanks again for everyone's comments/insight.
Brian, Stacy, and the kids
2011 F-250 CCSB 6.7L PSD 4WD
2013 Palomino Solaire 269BHDSK
ProPride Hitch
07-02-2015, 07:07 AM
#31
Your last scenario is the correct way to do it. Cord cannot be used as a permanent wiring method and your original method is really a hybrid of permanent and portable which is in fact a code violation. You should be fine with #10 AWG for 60'. Master electrician with over 35 years of commercial experience.
07-02-2015, 07:42 AM
#32
I don't think you even need 30amps unless you plan to run A/C,,,
Of course it would be nice to have that available !!!
I did see a 30amp plug @ Menards yesterday !!!
07-02-2015, 10:00 AM
#33
jumper cable ends | eBay
07-02-2015, 10:41 AM
#34
Toadman
I had an electrician install mine at my old house. He bought an outside electrical box with a hinged cover and installed a female plug inside with all the wiring necessary. Mounted on a pole I had near the trailer and it worked great. I still used my TT cord though because it was conveniently close by. I should mention that he bought all of the materials at Home Depot.
07-02-2015, 10:51 AM
#35
I did as well. Tapped in to the electrical box ran wire under house and attached a 30 amp connector to the wall
