Old 07-02-2015, 07:07 AM   #31
Your last scenario is the correct way to do it. Cord cannot be used as a permanent wiring method and your original method is really a hybrid of permanent and portable which is in fact a code violation. You should be fine with #10 AWG for 60'. Master electrician with over 35 years of commercial experience.
WY Husker Fan is offline   Reply With Quote
Old 07-02-2015, 07:42 AM   #32
Wolverine 1945's Avatar
I don't think you even need 30amps unless you plan to run A/C,,,
Of course it would be nice to have that available !!!
I did see a 30amp plug @ Menards yesterday !!!
Wolverine 1945 is offline   Reply With Quote
Old 07-02-2015, 10:00 AM   #33
mike.t's Avatar
Originally Posted by waiter21 View Post
When I made my 50ft extension cord, I bought a 50ft 10/3 welder extension cord on e-bay, cut the ends off and installed RV 30 amp connectors. Cord and connectors, I think I have $75 in it. Now that I carry it in the MH, I'm betting I will never need it. :-)
NOTE - I prefer to carry multi purpose components - I'm thinking about making a couple short adapters that I can plug into this cord and they'll have alligator clips on the ends, This would give me a 50ft long jumper cable. I've needed that a couple times. :-)
jumper cable ends | eBay
2015 Salem 27RKSS
2015 Ram 2500 CC 4x4 Cummins
55' Chevy Bel-Air
Burgers on the BBQ and a cold beer
mike.t is offline   Reply With Quote
Old 07-02-2015, 10:41 AM   #34
Toadman
I had an electrician install mine at my old house. He bought an outside electrical box with a hinged cover and installed a female plug inside with all the wiring necessary. Mounted on a pole I had near the trailer and it worked great. I still used my TT cord though because it was conveniently close by. I should mention that he bought all of the materials at Home Depot.
Toadman is offline   Reply With Quote
Old 07-02-2015, 10:51 AM   #35
mike.t's Avatar
I did as well. Tapped in to the electrical box ran wire under house and attached a 30 amp connector to the wall
2015 Salem 27RKSS
55' Chevy Bel-Air
