Old 08-05-2015, 10:02 AM   #21
Originally Posted by Micahnkel View Post
We plug in our 2014 servory cadet by forest river and it trips the GFI plug every time also drains battery so we took it in to the shop found out when wiring the trailer the stapled into one of the wires therefore grounding out. Replaced wire replaced converter and new batteries, take it home plug it in trips GFI and still won't hold charge drains batteries in few hours we charge the batteries with generator. Only way we have any power is with generator. Please help with any info trailer has been in shop for 3 weeks
It is possible that your converter is powered by your GFI circuit. If that is the case, and your batteries will not hold a charge, it's possible the wire from the converter to your batteries is shorted.
It is also possible that you have a DC circuit shorted. When you plug the trailer in the short-circuit could be causing an excessive load on the GFI circuit causing it to trip.
Is it the GFI plug that is tripping or is it the circuit breaker for that circuit? If it is a plug which one? That might help us to narrow it down.
Jim
07 Dodge 1500 crew cab with 20" wheels, 08 Forest River Rockwood Signature Ultra-lite 8280SS
"The reasonable man adapts himself to the world; the unreasonable one persists in trying to adapt the world to himself. Therefore, all progress depends on the unreasonable man."
George Bernard Shaw
oldtool2 is offline   Reply With Quote
trailer
