Old 11-15-2015, 10:44 PM   #11
Originally Posted by rockfordroo View Post
Get one of these at wallyworld;
Ge 50542 Receptacle Tester - Walmart.com
The three prong tester is good, but a non-contact voltage detector might be a better choice. It can test the neutral and hot wires in an outlet separately and can also alert you to a "hot skin" condition on your RV.
This video explains how to use a non-contact voltage detector:
2016 Sunseeker 2300C
SS Cruiser is offline   Reply With Quote
Old 11-16-2015, 09:39 AM   #12
Originally Posted by woodpile View Post
I'll try and be brief. I got home with my new TT and plugged it in to an outbuilding on a 20amp breaker. Sometime later I discovered I had no power to the building but the breaker was not tripped. after a while I found a portion of the wire (common?)to be shorting out and I replaced it. I moved the camper and plugged into another building on a separate breaker box and after several days I noticed the outlet had no power and the breaker was not tripped also. I never turned on the air, water heater, fridge, microwave, etc. I only plugged in to keep the battery charged and use some lights. At this point I suspected the TT was causing the problem??? We made several trips and no problem at the campground. I since have installed a RV 30 amp breaker box on a designated circuit and no problems. Since this has only happened to circuits I have plugged the TT into I suspect the TT has a problem with the wiring that will show its ugly head at some point. Any helpful advice will be appreciated. Well, any humorous sarcastic help will be accepted.
You are only plugged into a 20 amp breaker. If you try to run the ac with the hw heater switched to 110 vac, or the ac and microwave together you will trip that 20 amp breaker. Your trailer is at least a 30 amp system so running those things together causes an overload.
I have gotten in the habit of shutting the ac off if I need to use a toaster, coffee pot, microwave or anything else that draws a heavy load. The hot water heater cycles on and off when switched to 110 vac. It is quiet so you don't realize it.
Jim
07 Dodge 1500 crew cab with 20" wheels, 08 Forest River Rockwood Signature Ultra-lite 8280SS
"The reasonable man adapts himself to the world; the unreasonable one persists in trying to adapt the world to himself. Therefore, all progress depends on the unreasonable man."
George Bernard Shaw
oldtool2 is offline   Reply With Quote
Old 11-16-2015, 09:43 AM   #13
A better choice than this is a surge detector. A portable one checks everything before you plug the trailer in.
Jim
George Bernard Shaw
