Old 06-27-2013, 06:43 PM   #21
wmtire's Avatar
Originally Posted by outdoor cooker View Post
I have tried three different circuits n my garage and still same problem. Think something wrong with camper. Not sure what.
You are not using any kind of other extension cord between the trailers power cord and any of the three outlets in your garage?
2011 Flagstaff 831 RLBSS
Iíve lost my scapegoat.
Old 06-27-2013, 08:07 PM   #22
outdoor cooker's Avatar
Would the GFCI circuit n the camper still b a factor even if the breaker is turned off n the camper?
outdoor cooker is offline   Reply With Quote
Old 06-27-2013, 10:13 PM   #23
No other cords just power cord from camper to receptacle.
Old 06-29-2013, 10:49 AM   #24
Had time to check things out little more. Took GFCI out of garage n one circuit, camper works fine. Weird thing is camper has been plugged n with a GFCI receptacle since I bought it n march on 2012 with no problems. Thanks for ur help.
Old 06-29-2013, 12:52 PM   #25
TURBS's Avatar
Solved!
Old 06-29-2013, 01:34 PM   #26
dcheatwood's Avatar
Don't you Love having all this knowledge at your fingertips? I get solutions to problems I haven't even posted, just by reading and following other's posts. Thanks guys.
2013 Rockwood 8282WS
Reese Revolution Pin, Reese 16K
2008 Tundra Limited Double Cab 5.7L
Air Lift 5000 w/Wireless Air
Old 06-29-2013, 01:52 PM   #27
Herk7769's Avatar
GFCI to GFCI is "unreliable" not "won't work."
HAM CALLSIGN - KC3FFW
Old 06-29-2013, 02:19 PM   #28
Oklahoma Proud
MillerTime's Avatar
My electrician buddy says that gfci outlets are not to be used for motor type( larger I believe he meant) appliances - ie compressors, chopsaws, welders etc. They are not reliable because of the starting of the motor-it will trip them sometimes. Had it happen on one of my compressor outlets and it would trip the breaker.
Just stating what I was told.
