Old 11-24-2014, 11:05 PM   #1
Plugs in belly storage
I am spending the winter in the camper so I have wrapped my water line with insulation and heat tape. I plugged the heat tape into the outside plug but it is throwing the GFCI breaker in the bathroom. It worked for about a week or so then all the sudden it started throwing the breaker.
Since I need to have it plugged in I am wondering if I can plug it in in the belly. There are two outlets in there but both only have one plug. There is one that is right next to the inverter on the right side and one that the water heater plugs into. What I would like know is what does the plug on the right side next to the inverter power. I can't see where the wire plugged into that side is going to. Does anyone have any idea what this powers?
Any suggestions on what I can do with these plugs to make sure I can keep my water line heated?
DuckCamper is offline   Reply With Quote
Old 11-25-2014, 08:52 PM   #2
Your make & Model???
Central vac plug?????
Jim in Halifax is offline   Reply With Quote
Old 11-25-2014, 09:38 PM   #3
VinceU's Avatar
It would help you to know if the GFCI is operating on too much power draw (amps) or because there really is a ground fault. Most likely the other outlet in the basement is also on the same GFCI circuit, easy enough to check, add a lamp to that outlet with the GFCI in use, then trip it. As for the cause of tripping, you can easily separate the wires at the supply end and apply a current clamp to check load. Last resort would be change the GFCI outlet, they are cheap and fail often
Old 11-26-2014, 05:50 PM   #4
I forgot the model number which would be good to know..Sorry
It is a 2014 37BH.
I didn't think about it going to the central vac but that is likely. I will try the vac when I get back after Thanksgiving.
Also, I did test it to see if it was on the same circuit as the GFCI plug and it isn't because it was working when the GFCI was still off. I will try and plug some other things into that circuit and see what happens, again once I get back.
Is there any way to get a wiring diagram for this camper. I would like to put a 12v plug outside for some LED lights also.
Old 01-07-2015, 07:52 PM   #5
I finally remembered to reply. The plug in the belly right in front of the main entry door is for the central vac.
Thanks for the help.
storage
