Old 10-14-2014, 03:23 PM   #21
fonzie's Avatar
Originally Posted by GASPEDDLER View Post
Guys, is this adapter all I would need for my setup? My TT is 30amp and my generator also has the 30 amp 120/240 4 prong outlet. Also the gen plug has a 120/240 toggle switch located next to the 4 prong plug in question and I'm guessing choosing 240 v would be a mistake, Or would it matter since the adapter would eliminate one leg of the 240 from entering my TT. My generator is 5550 continuous watt and 8500 watt start up rated, would that power a 15k AC? Sorry to hijack the thread and thanks in advance.
Yes you should be OK with this adapter but you will only have about 23 amps available to power your trailer as it is a 5550 continuous watts generator. It should power your 15K AC but will have to do load management not to overload circuit breaker on generator.
Fonzie
Old 10-14-2014, 03:30 PM   #22
GASPEDDLER's Avatar
Fonzie, I'm i wrong to assume my 15k ac will pull about 15 amps? Am I low in my estimate? What's the best way to gauge usage? I have a surge suppressor I could use with a digital display but I wonder if fluctuations in current by the generator might cause the suppressor to cut off electricity to the TT.
2012 F-350 4x4 King Ranch Super Duty CC 6.7 Turbo Diesel 3.55 e-locker
2011 Palomino Puma 30KFBDS with Side Paw Kitchen and Bunkhouse
Equalizer E2 Hitch
GASPEDDLER is offline   Reply With Quote
Old 10-14-2014, 04:20 PM   #23
fonzie's Avatar
Your 15K AC unit will draw app. 15 amps running. On start up it might draw up to 30 amps but for a very short duration which with the rating of your generator should be able to handle it. It all depends on how much extra load is already being used eg: water heater, fridge, converter etc etc....I use a progressive industries EMS management and I can see directly how much is being used at any time. For your surge suppressor only you can test and see how it works with generator and TT load hook up. It's never a clear cut answer with electricity usage as a lot of factors have to be taken into account.
Fonzie
Old 10-14-2014, 04:36 PM   #24
If you don't own a circuit tester.. I would be worth it to pick one up... Been to a few campsites and was able to catch messed up 50amp plugs before any damage... One had a 240 leg... ( camp site maintenance guy said it was wired correctly one of his guys changed it a few days ago..had to take him to another site to show him) that would have been a costly mistake... And more than a few had one of the 120 legs dead....
So now before I level up...I get out and check the outlet...(grounds, neutrals and legs)
2010 Georgetown 300FWSSouth Florida
speedjester is offline   Reply With Quote
Old 10-14-2014, 04:46 PM   #25
wmtire's Avatar
SAY IT LOUD, BROTHER!!!!!!!!
This excellent advice above cannot be repeated enough until we all practice this. If you don't have any kind of electrical management system that will automatically shut down power if something is wrong.....then you must make it part of the camping ritual to test the outlets EVERY time before you connect.
If you don't know how, or may even want to make a plug n play tester....then you can gain that wisdom from this site:
http://www.myrv.us/electric/
2011 Flagstaff 831 RLBSS
Iíve lost my scapegoat.
Old 10-14-2014, 06:12 PM   #26
hrlyguy2's Avatar
After reading everything here.
So A 50 amp rv needs a generator adapter 50 to 30 amp .But cannot use a dog bone adapter and a 30 amp cord too!!
Just making sure when the time comes I will set if needed
Generac 6500 watt generator.And 8500 start up
Since we on this thread already .
2007.5 Chevy 3500Ltz cc lb Duramax
2010 Sandpiper 345 RET (SOLD)
hrlyguy2 is offline   Reply With Quote
Old 10-15-2014, 07:50 AM   #27
RV Electric
Wmtire..
Thank you for such a helpful and informative Link .. There is so much information to be learned on that website and videos .. I and the wife are fairly new to Rving .. less then a years exp. Nobody .. from both dealers of which we purchased units from included that information during delivery.. And from all the friends and 4 locations we currently camp at this topic of checking the Electrical hook up prior to using has never been brought up nor have I witnessed anyone doing.. A definite new procedure for us prior to setup ... Thanks again
Vonner is offline   Reply With Quote
Old 10-15-2014, 09:02 AM   #28
wmtire's Avatar
You're very welcome. As speedjester pointed out, you really do not know what has happened at ANY outlet previous to you plugging in. You never know what the previous camper, electrician, or park person may have done before you..........or shorted out.
Also as with anything electrical or mechanical, things just break or wear out.
I would advise even checking your own generator before plugging in, as things can become loose/disconnected from the vibrations when running.
You may be lucky and never encounter a problem...........but it's that one time you do catch a problem that makes you glad you did check first. There are actually many posts in these forums just like speedjesters, so it's more common than one may think.
You can also purchase either hardwired or portable Electrical Management Systems (EMS) that will do a lot of this checking automatically for you.....as well as having a surge protector.
Here is a link to a 50 amp hard wired one.
http://www.progressiveindustries.net/ems_hw50c.htm
A surge protector is another good item to have...... which you can purchase as a cheaper standalone item, or built into an EMS.
Old 10-15-2014, 10:58 AM   #29
TURBS's Avatar
Ok I have to put my 2 cents in this thread.
If any of these generators have the 240/120 30 amp four female outlet you will NOT have 30 amps available!
The 240/120 outlet has a floating neutral and has a max amps of 30 on the "240v" side which you will not be using.
Since you've dog boned it down you'll be using the "120v" portion of this outlet and MAX amps will be cut in half to 15 amps.
Been there done that!
Turbs
Old 10-15-2014, 11:04 AM   #30
TURBS's Avatar
To slightly edit my above post you'll have 15 amps on each leg available.
For a total of 30 and from my experience 15 amps on each leg will be absolutely marginal.
More like 12-13 amps.
Turbs
breaker, generator
