Old 10-15-2014, 02:46 PM   #31
Ok... now for an update .. Using the 4 prong to 50 .. I had no issue running my AC 15k .. I also turned on all lights one tv ( smaller one in the Bedroom) .. but when I tried to run the microwave .. Boom all shut down.. I checked fuse box ( circuit panel) and nothing popped .. Checked the Generator and the Breaker again popped ..
Now I have another concern .. Upon starting the generator again and walking into the trailer I noticed a Green light blinking on the circuit panel .. I do not recall this green light blinking .. Is this normal.. I checked everything and nothing seems wrong all lights AC, tv etc turns back onl.. I tried to read the microscopic wording around the light.. But these eyes aren't what they used to be.. Checked my manual as well as online.. Cant find anything on what this green light represents ..
Vonner is offline   Reply With Quote
Old 10-15-2014, 04:53 PM   #32
fonzie's Avatar
Originally Posted by hrlyguy2 View Post
After reading everything here.
So A 50 amp rv needs a generator adapter 50 to 30 amp .But cannot use a dog bone adapter and a 30 amp cord too!!
Just making sure when the time comes I will set if needed
Generac 6500 watt generator.And 8500 start up
Since we on this thread already .
It is best to have the proper adapter if you want to have double the current available from your generator if it has 120/240 30 amps receptacle. With your 6500 watt generator(dual voltage), you should be able to have 27 amps per line (total 54 amps) to feed your 50 amp RV plug. If you use a dog bone 30 to 50 RV adapter as shown in this thread, then you will only have 27 amps total available to feed your 50 amp RV plug.
Here is good site that explains RV electrical.
RV Electrical Systems
Fonzie
Old 10-15-2014, 04:58 PM   #33
fonzie's Avatar
Originally Posted by f1100turbo View Post
To slightly edit my above post you'll have 15 amps on each leg available.
For a total of 30 and from my experience 15 amps on each leg will be absolutely marginal.
More like 12-13 amps.
Turbs
Turbs what you mention here is correct if the OP had a 3600 watt dual voltage (120/240 volts) generator with a 30 amp receptacle. Since he has a 5550 watt generator, my post #7 is correct in this instance.
Fonzie
Old 10-15-2014, 05:06 PM   #34
fonzie's Avatar
As I mentioned in post #21, you have to manage your load. Depending how your appliances are connected into your ac distribtiton panel, either on L1 or L2, you can overload the circuit on that particular line and trip the main circuit breaker on the generator. Remember you only have 23 amps per line and not 50 as if you were hooked up to a power post at a campground.
For your green light, check this tread.....
Little blinking light on breaker panel
Fonzie
Old 10-15-2014, 07:14 PM   #35
hrlyguy2's Avatar
Asked the company Generac about it.
this is what I recieved.
Thank you for contacting Generac Power Systems. My name is Sara and I will be assisting you*today. At this time we do not manufacture an RV adapter for the generator. Also, to get the full output of the generator, you will have to use all outlets. If you have any other questions please let us know. Again thank you for contacting Generac and have a great day!
2007.5 Chevy 3500Ltz cc lb Duramax
2010 Sandpiper 345 RET (SOLD)
hrlyguy2 is offline   Reply With Quote
Old 10-15-2014, 07:44 PM   #36
fonzie's Avatar
Not much information here....more like bla bla bla........
Fonzie
Old 10-15-2014, 08:38 PM   #37
TURBS's Avatar
Is this a gp series generac that we are speaking of?
Because the op clearly states he is using the 4 prong 240/120 plug in.
Which is the dual outlet.
Turbs
Old 10-16-2014, 08:24 AM   #38
GASPEDDLER's Avatar
Anyone see a problem with me running my 5500/8500 generator in the back of my truck in case of bad weather (rain). I will open the tailgate and all three windows to allow for ventilation/cooling. I also plan to park the truck downwind and at a distance from the TT. This will also prevent me from having to unload the 170 pounder.
Name:	ImageUploadedByForest River Forums1413465870.104814.jpg
2012 F-350 4x4 King Ranch Super Duty CC 6.7 Turbo Diesel 3.55 e-locker
2011 Palomino Puma 30KFBDS with Side Paw Kitchen and Bunkhouse
Equalizer E2 Hitch
GASPEDDLER is offline   Reply With Quote
Old 10-16-2014, 08:28 AM   #39
TURBS's Avatar
Attachment 64830
I would if I had a topper.
Albeit we have dry camped with gennie running in a full downpour.
They do get hot so ventilation is key especially since there air cooled.
Check on it occasionally when first starting.
Only thing I'd be concerned about is a fuel leak and subsequent explosion!
Turbs
Old 10-16-2014, 08:38 AM   #40
GASPEDDLER's Avatar
Good point Turbs. I guess I'll only leave in the back of truck if the weather turns to rain, otherwise it will stay on the ground. I'm also hoping for cool weather so there should not be a need to run generator to power the ac. Although there's no way to know whether it will be in the 40's or 90's in November in Texas.
Equalizer E2 Hitch
breaker, generator
