Old 06-25-2018, 10:54 PM   #1
Sewgratefulquilts's Avatar
Portable Inverter Alarm
Can anyone explain why a Schumacher 750W portable inverter would sound an alarm with only Wally Dish receiver plugged into it? TV on. Nothing else on. Battery monitor on Motorhome says batteries are 11.9 but multimeter says 13.12 and 13.27. Batteries are Trojan Deep Cycle 27.
Had same problem with cheap Walmart 450W inverter which was a “hand me down” from my brother so I bought a new bigger and better one.
Sewgratefulquilts (Linda)
2017 Class C Forester 2371 Transit Series
Hubby, Craig, and Miniature Poodle, Beau
Sewgratefulquilts is offline   Reply With Quote
Old 06-26-2018, 06:24 AM   #2
SeaDog's Avatar
With both batteries at full charge, If both inverters have alarmed with low voltage and your coach is showing low voltage it sounds like you have something between the batteries and inverters that is drawing the voltage down. I don't think its the inverters.
Retired Navy
2016 Flagstaff 26 FKWS
Old 06-26-2018, 08:50 AM   #3
This morning my coach battery monitor says 12.4 and both batteries read over 14 with the multimeter. Didn’t run the generator or plug in solar panel. How can I have more battery power this morning? This isn’t the first time this has happened but it never happened before I bought the inverter.
Old 06-26-2018, 09:49 AM   #4
i'd table the concern about the inverter and look into why the the significant different between the battery monitor and the batteries themselves. which is correct? if the battery monitor (11.9 volts is correct) the inverter may be seeing a low battery condition, especially if it is portable and has to be plugged into something some distance from the batteries. inverters are normally installed within a couple of feet of the batteries.
2015 cardinal model 3825fl
2015 dodge ram 3500 dually
CHICKDOE is offline   Reply With Quote
Old 06-26-2018, 09:55 AM   #5
Flybob's Avatar
I would not trust the multimeter. If your batteries read 14V after a night of use and they were not being charged, something is wrong. Batteries sitting over 8 hours with nothing charging them should not be 14V.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
Old 06-26-2018, 02:07 PM   #6
SeaDog's Avatar
Are you plugged into shore power?
Retired Navy
inverter
