Old 10-12-2019, 02:36 PM   #1
NXR
NXR's Avatar
Possible compatibility problem with Precision Plex holding tank/elbow heater system
If you have the Precision Plex tank heater system in your RV and it gets near freezing for you, you might want to read this thread I just put on the Georgetown forum.
In a nutshell, the Precision Plex system is programmed to require that the house batteries be at a minimum of 13.3 VDC before they will turn the heaters on, but the Progressive Dynamics PD9270 Converter/Charger drops its voltage to 13.2 VDC if the house batteries have not been used in 30 hours.
Link: A caution on the Precision Plex holding tank and elbow heater system
I'm posting this here because I know the Dynamax also uses the Precision Plex system but I have no idea of those capabilities other than it's a lot more than the Georgetown. There also may be other models using the Precision Plex with the same programming mis-match.
FWIW,
Ray
2020 Georgetown GT5 34H5
NXR is online now   Reply With Quote
heater, tank
