01-02-2012, 07:34 PM
Possible converter problem
We were running our heat and I noticed the fan sounded slow so I checked the battery level and it was low. The battery was almost 5 years old so I thought it was bad. We got a new battery and late the same night the same problem, got down to 1/3 on battery meter. During the day the battery would charge back up.
Also I tried just unhooking battery and let the park power run everything and that did not work either. The 12 volt lights would blink and the propane detector would make noise.
My understanding was you could run without battery if you were hooked up to park power.
It is a 2008 flagstaff with a parralax converter
Has anyone had this experience?
01-02-2012, 09:18 PM
No trouble like that, but-- consider purchasing a VOM. Then, measure the voltage to your battery.
Check internal fuses, and so on.
Mike
01-02-2012, 09:44 PM
I had a similar problem on my 2011 Sabre. If I cycled the power to the converter, it would start to run again until it got the battery almost full then would quit and not start again until I cycled the power again. The converter was under the manufacturer warranty (the coach was 10 days out of warranty) so they (the converter maker) replaced the converter. It took them alomst 3 weeks to get one back to me.
When my converter was out getting checked out by the manufacturer and when it was on the fritz, I just hooked up my intelligent battery charger (has automatic float) to the battery and every thing was good.
To the best of my knowledge, you will need the converter working or a battery charger to run any 12 volt items as it keeps the battery charged to run the 12 volt side which runs off the battery. My coach would not run any 12 volt items without a good battery.
Mike is right on, you really should check the voltage at the battery. With the converter running is should read ~ 13 volts. If it is lower than 12, then it would appear that the converter could be bad.
HTH
Jim
TV, 2000 Dodge RAM 2500 Quad cab short bed, Cummins 5.9, Edge Comp, Gauges.
5ver, 2011 Palamino Sabre 31 RETS.
01-02-2012, 10:36 PM
First and easiest, check all your breakers. Then check the two large fuses in the converter panel. My converter will every once in a while trip a breaker. If you don't know which one, turn them all off, then back on, one at a time. After that, you will need a meter.
LadyWindrider
2012 Ford F250 ext. Cab 4x4
2002 Jeep Wrangler Sahara
2008 Work and Play 18LT
01-03-2012, 08:22 AM
My money is on a corroded ground.
A high resistance ground connection will give you ALL the symptoms you describe.
Remove the battery ground wire from where it is screwed to the frame member. SAND the terminal and the frame hole (lightly on the inside as well) and using a NEW screw of the same size, reattach it to the frame.
Check charging status with a voltmeter (or light).
Lou & Freya the wonder dog
2019 Flagstaff 8529FL
01-03-2012, 08:37 AM
I will check it today and let you know what I find.
01-03-2012, 11:28 AM
Went out and checked breakers and fuses all were fine. Checked with volt meter and it said 12.3 so I unhooked battery and the volts were 3.2 with just the wires.
I also cleaned the ground and same result, 12.3 volts at the converter also.
What do you think?
01-03-2012, 12:22 PM
Typically:
A. 14.2 volts Normal charging voltage for a 12 volt battery.
B. 13.2 volts Voltage for a fully charged 12 volt battery.
C. 12.5 volts The point at which a 12 volt battery is 50% discharged.
D. 11.6 volts The point at which a 12 volt battery is "fully discharged".
Charging a battery requires higher voltages than the battery already has.
My next step would be checking the voltage right at the converter. Charging also requires a connection at the battery, else the converter won't produce (generally) a high voltage and necessary current.
So-- ensure proper connections, find the exit wiring of your converter and a bare post, then measure the voltage with a dead battery. Measuring with a charged battery will not show charges, and if it does, then you've a problem with the converter.
Your meter should read around 14.2 v because you are attempting to charge a depleated battery.
As a battery charges, the voltages and currents from "good" converters or chargers diminishes, thereby not over charging, which is equally damaging, or more so.
Batteries that boil dry because of excessive charging die quickly. When plates in a battery dry, that cell or cells is essentially a drain and the life expectancy is sometimes only a day or two. Therefore, check for proper levels in solution, clean the tops of the batteries and ensure tight connections.
Also, you might take your battery(s) to a battery supply house for a quick check. These companies, if reputable, will put the battery under load and determine it's capacity. But, be cautious as all companies are in the business to sell you new products.
Finally, should you find an adequate voltage at the converter, then trace the wiring to your battery. You may have a connection that's broken, called an open. If you do, then replace the entire run with properly sized wire and quality (that used by RV's and autos).
If you don't have enough voltage at the converter, then check the converter for internal fuses, assuming you have 110 at the unit itself. Remember, 110 is a dangerous voltage as it's sine is approximately your body sine. Following safety procedures is a critical element.
01-03-2012, 01:56 PM
What do you think?
OK, 12.3 across the battery terminals with the converter powered, right.
Confused about the 3.2 volts. Was this across the battery(s) with the converter wires disconnected? Not the voltage across the converter wires with the battery disconnected and the converter powered.
When you say 12.3 at the converter I assume you mean in the power panel. Was this with the converter powered and the battery connected or disconnected? Check the power center output only with the battery disconnected.
The attached file has the troubleshooting procedure on page 8.
If the battery stack (two 6 volt batteries in series) is only reading 3.2 volts, it is too dead to charge with the converter. You will need to remove the batteries and hook them up to a battery "re-conditioner" with a "desulfator" circuit. This will blast the sulfates off the plates and back into solution.
01-03-2012, 06:49 PM
Checked voltage when I got back from work and it was back up to 13.5 at the converter and 13.3 at the battery.
Does the furnace draw so much power my converter can't keep up?
Herk, the 3.2 volts were at the wires that hook to the battery (not hooked to battery). I thought that it would show how much charge the converter was putting out.
01-03-2012, 09:41 PM
If I'm following the tread correctly, the converter is unly putting out 3.2V? Can you (or did you) check he output voltage at the converter and compare it to the 3.2V that you got at the battery connection wires?
Fire Instructor
2022 Coachmen Leprechaun 319MB
2022 Ford Ranger toad
01-03-2012, 10:18 PM
It was but now it is putting out 13.5 volts. I don't know if something was loose in it or what. I pulled it out and moved it around this morning and when I got home it was at 13.5 volts.
One thing I did notice is sometime our gfi and converter breaker will trip so I tripped it and the lights got dim like before. The correct voltage came back in a few minutes after i cut the breaker back on.
I don't know what is going on. I will keep a watch on it for a few days.
01-03-2012, 11:36 PM
Trace the POSITIVE battery lead. It should go to a circuit breaker, shortly behind the tongue. Check the connections on that breaker for clean and tight. 3.2 volts out of the converter is wrong. Also check the voltage on both sides (terminals).
LadyWindrider
01-03-2012, 11:46 PM
My vote is still corroded terminals. If the grounds are good then the "hot" side is the most likely culprit like Windrider said. Sounds like the pulling and prodding you did might have momentarily made a better connection.
01-04-2012, 06:36 PM
I will give the hot side a check saturday.
Thanks everyone,
Travis
