Old 09-01-2015, 06:30 PM   #1
GLCM Warrior
Lefty59's Avatar
Possible Electrical issue?
On a recent 3 week trip we noticed that fairly often the FM radio would fade/cut out when another electrical appliance was turned on/off. For example, use the microwave...radio fades out. Open refer door...radio fades out. Turn on porch light...radio returns to normal. Next time we turn on porch light...radio fades out. No real rhyme nor reason that we could discern to what would cause it to fade out or to return to normal...but the radio change always seemed to occur when some other electrical device (AC or DC) was turned on or off. We've noted no other electrical problems in the RV...only the radio issue. Problem occurred at several different campsites, so I'm not thinking the power source was the issue.
Is this an indication of a radio problem...or possibly a bigger electrical issue? I'm thinking it might be a possible grounding issue either with the radio itself or the converter. Looking for help in deciding where to start troubleshooting.
RV is wired for 50 amp service but we typically use an aftermarket 30 amp cord to hook up as we only have one AC (as of now) so no real need for 50 amp service and the 50 amp cord is very cumbersome.
Thanks!
2014 Wildcat 312QBX
2014 Ford F350 SD 4X4 CC LB 6.7L PSD
Bob & Debbie, USAF Retired
Lefty59 is offline   Reply With Quote
Old 09-02-2015, 07:52 AM   #2
Head Rambler
When you say that the radio fades out, do you mean the signal is fading out or that the power to the unit is fading out?
Gotta go campin!
Old 09-02-2015, 06:37 PM   #3
GLCM Warrior
Lefty59's Avatar
Mostly, signal/sound fades out...almost like someone hit the mute button & half-muted the radio. Sometimes, we pretty much lose the station altogether...just get mostly static.
Power seems to be okay. Never notice any change there.
2014 Wildcat 312QBX
Old 09-03-2015, 08:40 AM   #4
Head Rambler
It sounds like the converter is causing some radio interference. You could try isolating the radio power from the converter and see if it still happens. If it doesn't then I'd suspect the converter circuitry is failing.
Gotta go campin!
electric, electrical
