Old 05-08-2015, 03:09 AM   #11
bikendan's Avatar
Originally Posted by airforceguyiniowa View Post
Fridge and microwave do not power up
That doesn't make sense.
The microwave is 110v AC only, not 12v DC.
Why is tv and outlets working but not microwave?
Can't just be a 12v issue.
Dan-Retired Firefighter/EMT
Equalizer WDH and Prodigy BC
Old 05-08-2015, 06:49 AM   #12
TURBS's Avatar
Fridge is 12v "battery powered" microwave is 110v "shore power"
1] you should have "2" gfci outlets.
One in bathroom and one in kitchen.
2) check 12v fuses in converter for fridge and also there's 2 fuses outside in the fridge access panel in a black box
TURBS
08 duramax tuned n modded, 32bhok Sabre
2015 camping "4 nights"
Old 05-08-2015, 07:36 AM   #13
jtstromsburg's Avatar
Check those two big red 40a fuses near the smaller ones. I haven't had to deal with this exact issue. So am not sure what to look for, but I know there's fuses you can't usually see until you take things apart like you have here. Keep looking at those higher amperage fuses
Joel and Teresa
2016 Sabre 34TBOK
2006 GMC 3500 CC LB DRW 4X4
jtstromsburg is offline   Reply With Quote
Old 05-08-2015, 07:50 AM   #14
TURBS's Avatar
Your camper is still under warranty is it not?
TURBS
Old 05-08-2015, 09:06 AM   #15
airforceguyiniowa's Avatar
Probably, it's a 2014 model, just want to make sure if its something I can fix, dealer is a pain, takes forever, and Memorial Day is fast approaching.
airforceguyiniowa is offline   Reply With Quote
Old 05-08-2015, 09:08 AM   #16
TURBS's Avatar
To bad your not a little closer I'd run over n help you out.
TURBS
Old 05-08-2015, 09:09 AM   #17
TURBS's Avatar
First you need to look in the frf library and look at the wfco trouble shooting guide.
Is your battery dead in camper?
TURBS
Old 05-08-2015, 09:14 AM   #18
wmtire's Avatar
My question was similar to Turbs, and wanted to make sure you have a battery in your RV and have you recently connected or disconnected it?
2011 Flagstaff 831 RLBSS
Iíve lost my scapegoat.
Old 05-08-2015, 09:19 AM   #19
TURBS's Avatar
We know it's not the curcuit breaker under the A-frame because 12v is getting in from your truck.
So.
1) dead / junk battery.
2) blown reverse polarity fuses.
3) bad converter and dead battery.
TURBS
Old 05-08-2015, 11:34 AM   #20
fonzie's Avatar
Check the two 40 amps fuses to see if burnt. If these are burnt then most likely your battery is hooked backwards, if all OK then go check underneath trailer near tongue for a mini-breaker and press black button to reset....tat is a start.
ID:	76436   Click image for larger version
Fonzie
camper, power, truck
