Old 05-08-2015, 12:03 PM   #21
Originally Posted by TURBS View Post
To bad your not a little closer I'd run over n help you out. TURBS
You could go out of character and be a nice guy meeting him halfway!
Old 05-08-2015, 12:08 PM   #22
TURBS's Avatar
Originally Posted by fonzie View Post
Check the two 40 amps fuses to see if burnt. If these are burnt then most likely your battery is hooked backwards, if all OK then go check underneath trailer near tongue for a mini-breaker and press black button to reset....tat is a start.
Can't be the curcuit breaker as I previously stated because when he hooks the tv up to trailer he has 12v power.
So with that being said.
Either battery is dead or junk or missing.
Converter is junk or bad fuse.
TURBS
08 duramax tuned n modded, 32bhok Sabre
2015 camping "4 nights"
Old 05-08-2015, 12:10 PM   #23
TURBS's Avatar
I would if I d I dnt have to prepare for a graduation party
TURBS
Old 05-08-2015, 02:00 PM   #24
Power Converter failure
Your lower unit in the converter can easily be checked with an automotive style test light. Disconnect the large red wire from the right side. Attach the ground clip to the ground lug near the red wire lug.Check for 12 volts. ( the light on your test light should come on.) when you touch the light to the large red wire, if not your lower unit is bad and can easily be replaced. Do you have a battery in the camper if not this will cause the newer power converters to fail. Your battery and 12v side of the converter power all the lights and motors in the camper. The battery powers all the electronics such as monitor panels, circuit boards on appliances. Converter keeps the battery charged when plugged to 120 AC outlet.
hillsdaletc is offline   Reply With Quote
Old 05-08-2015, 02:03 PM   #25
I would if I didn't have to prepare for a graduation party. TURBS
It hurts to say this, but I know you would.
Old 05-08-2015, 03:10 PM   #26
airforceguyiniowa's Avatar
I will check all those when I get home, thank you for all the responses!
airforceguyiniowa is offline   Reply With Quote
camper, power, truck
