Old 05-07-2015, 08:13 PM   #1
airforceguyiniowa's Avatar
Power at camper main but nothing else until I hook up truck to camper
I'm plugged into my truck everything works. When I unhook truck no power in the camper. When I'm plugged into the house nothing works. Checked the main breaker in the camper panel has 120 volts, what should I check next?
airforceguyiniowa is offline   Reply With Quote
Old 05-07-2015, 08:27 PM   #2
speedcat's Avatar
Had a similar problem this past weekend. Check the converter. Mine is a silver box behind central vac in the basement of my fiver. I could be mounted on an interior wall behind your fuse box. My converter has two 35amp fuses. One was fried. Replaced it and everything fired back up again when plugged into shore power.
speedcat is offline   Reply With Quote
Old 05-07-2015, 08:31 PM   #3
RSchleder's Avatar
Not sure what you mean by 'everything" works? I'm assuming that since your hooked to your truck when you state "everything works", your saying all 12v items work? Right? If that's the case, when your plugged into 110v, your converter ( assuming you have a converter and not an inverter) should convert 110v to 12v and run the 12v items. Either your inverter is not working, or you have the trailer 12v "breaker" switch turned off. Mine is located on the tongue close to the propane tanks. Without knowing what rv you have, that's about all I can suggest with no further info!
Days camping (2016)----181 days
Days camping (2017) --- 82 days
2016 Wildcat MAXX 28RKX (33' TT), 2007 13' Scamp
2015 Ram Laramie Hemi, w/air suspension
30 years RV'ing
11 different RV's
RSchleder is offline   Reply With Quote
Old 05-07-2015, 08:33 PM   #4
Flybob's Avatar
Check the two 40 Amp ( orange) fuses.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
Old 05-07-2015, 09:00 PM   #5
All fuses are good
Old 05-07-2015, 09:00 PM   #6
27dbud model
Old 05-07-2015, 09:01 PM   #7
How do you know if inverter or converter?
Old 05-07-2015, 09:24 PM   #8
TV works, that's it, gfci outlet has power. So I guess everything 12v not working. Click image for larger version
Name:	ImageUploadedByForest River Forums1431051845.616467.jpg
Old 05-07-2015, 09:26 PM   #9
Fridge and microwave do not power up
Old 05-07-2015, 09:37 PM   #10
Gfci outlets and TV have power. Nothing for 12v stuff unless you plug into truck power.
camper, power, truck
