Old 09-19-2018, 08:28 AM   #1
Power converter
We have a 2017 EVO 2160 TT. Our batteries are fully charged. While plugged into AC, we disconnected the cables and tested the battery cables and converter cables. The battery cables tested 13.6v. The converter cables tested zero. Is there an inline fuse on the converter cables? We have no power with just the batteries on.
backazimuth is offline   Reply With Quote
Old 09-19-2018, 08:41 AM   #2
cavie's Avatar
Originally Posted by backazimuth View Post
We have a 2017 EVO 2160 TT. Are batteries are fully charged. When plugged into AC, we disconnected the cables and tested the battery cables and converter cables. The battery cables tested 13.6v. The converter cables tested zero. Is there an inline fuse on the converter cables? We have no power with just the batteries on .
The converter has a breaker I the panel box. The converter has two 40 amp reverse polarity fuses on it. There may be a battery disconnect switch. Do you have power at the shore power?
2002 27rk Wildcat 5er.
Port Charlotte Fl/Hinsdale Ma
Retired Master Electrician.
Old 09-19-2018, 09:36 AM   #3
You cannot get 13.6 from your batteries. I think you tested the converter and got 13.6 and the battery is disconnected, hence you got 0 volts. Check your battery disconnect.
2015 335DS
ScottBrownstein is offline   Reply With Quote
converter, power
