Old 08-31-2013, 02:49 PM   #1
mike54's Avatar
power converter
got up this morning to no 12 volt lights, no A/C, no fridge no 12 volt anything
110 is working I checked the breakers and fuses so the power converter is shot in my 2 yr old Rockwood I went to walmart and bought a battery charger to charge up battery so we will limp along until we get home Monday.
Mike & Marsha
2011 Signature Ultra Lite 8319SS
2005 Dodge Ram 3500 5.9 cummins diesel
http://www.facebook.com/WestAllisSunshiners
mike54 is offline   Reply With Quote
Old 08-31-2013, 03:01 PM   #2
fonzie's Avatar
Are you sure converter is gone? Have you check mini-breaker underneath front of trailer if it's tripped? Do you have multi-meter to check battery voltage?
Fonzie
Old 08-31-2013, 03:12 PM   #3
If the converter was working he'd have 12v even with no battery at all.
Old 08-31-2013, 03:17 PM   #4
fonzie's Avatar
True, forget my post.
Fonzie
Old 08-31-2013, 03:49 PM   #5
Brother Les's Avatar
have you pulled out the power converter and looked at it? with the 110 off, look over the wires and see if any soldering has broken loose. Check your wiring for corrosion or if any are loose connections somwhere. Are the lights working with your batt charged up? Unplug the 110, unhook the batt from the camper. Plug in the cable to your tow vehicle and start your tow vehicle. Do you have 12v lights inside the camper? Test around with a volts meter. Don't give up on your converter just yet.
Brother Les
converter, power
