Old 07-08-2012, 11:37 AM   #1
Old car's Avatar
Power converter issue
I'll try to be brief but some background info first--want to change my Coleman Mach thermostat to a Hunter digital so I went to my Dad's (retired electrician) so we could hook up to 30 AMP power to make sure everything would work right when we changed out thermostats.
Dad ran his 30 amp extension cord from his power panel in the garage and I plugged my standard TT power cord to it just like I would to the power pole at any campground. I heard a pop and went to my power panel in the Windjammer. A 15 amp breaker marked "GFI CONV" tripped and a little bit of smoke was hanging in the panel area. Flipped the breaker a couple of times but no power. One by one I reset every breaker from the main down through the entire panel. No power. Hooked the battery back up and now have power. Disconnected the battery and tried shore power again. Nothing. Pulled the breaker (the 15 amp that tripped originally) out of the panel and Dad put his meter to it. Got the proper readings and turned the breaker off and power was cut. Flipped the breaker on again and got readings again. So the breaker isn't fried and put it back in the panel. Put my 30 Amp to 20 amp adapter plug on the TT power cord and went to a standard outlet. Nothing. Hooked the battery back up and have power. Drove the TT home and seek advice. Did we fry the circuit board itself? Dad was a 40 year + working electrician and we have blown his mind as well as my trailer power.
Randy and Patty
2015 Sabre 33 CKTS-6 Platinum Edition
Reese 16K Slider hitch
2015 GMC Sierra 3500HD diesel dually
Old car is offline   Reply With Quote
Old 07-08-2012, 12:03 PM   #2
Herk7769's Avatar
Plugging a 110 volt camper into a 220 volt socket will do that.
"certified electricians" have destroyed more campers than anything.
Hopefully you will only be buying a new converter and not a new air conditioner as well.
Sorry,
HAM CALLSIGN - KC3FFW
Old 07-08-2012, 01:12 PM   #3
Old car's Avatar
Herk, just called dad and sure enough--the cord was hooked up for 220. The a/c was not turned on so I hope that was salvaged. The lights, fridge, etc. all seem to work off the battery. I would like to check the a/c before running it back into the shop. Can I turn on the a/c just for a moment to check it from the battery or hooked to my TV?
Randy and Patty
Old 07-08-2012, 02:12 PM   #4
sherdep's Avatar
Sorry,
I agree with Lou's statement about "certified Electricians"
I have ran into a few that really make ya wonder how they passed there exam - its kinda scary if ya ask me.
a/c runs on 110v so that would not be possible
you could pull the cover from the inside of the trailer and hard wire the a/c to a cord to test it if you really want to cut the end off of your extension cord.
forgot to add this - make sure the cord is "NOT" plugged in when you cut the end off so you dont get shocked or better yet hurt from the spark it will put off.
Most likely you fried the converter board and hopefully thats all that needs to be replaced.
2011 Rockwood Mini Lite 2306 - Matt
2004 Dodge Ram 1500 Qaud Cab 4x4 with 35" tires and 3.92 gears, Dynatech Longtube Headers & Fabtech 6" lift + Superchips with shift Tuning
Nights Camped 2011 (37) - 2012 (16)-2013 (2) -2014 (5) -2015(0)
USMC 91 - 95 - F/A-18 Aviation Ordnance
sherdep is offline   Reply With Quote
Old 07-08-2012, 06:17 PM   #5
Herk7769's Avatar
OK,
Here is what I would do at this point.
1) You know the converter is bad so turn the CONV circuit breaker off.
2) Plug into a 30 -> 20 amp adapter and plug it into a house duplex with NOTHING else on the circuit. If it is not alone just unplug as much as you can
3) Turn off all CBs in the power center. BUT make sure you have a charged good battery.
4) Turn on the CB for the air conditioner and then go to "COOL" setting the thermostat so it will try to start. If it starts and blows cold air you have dodged a major bullet.
5) Turn off the Air CB and turn on the Fridge CB. Turn the valves on the propane OFF. Press the "ON" button on the fridge the auto light goes on (a charged battery is needed for this step). If the CHECK light stays OUT and it starts to cool on AC you dodged another bullet. If the CHECK light comes on it means your AC is not working in the fridge. There is an AC fuse you might check.
6) The last big item is your TV. Check it to make sure it works OK.
Good luck, and hope it is just the converter.
Old 07-08-2012, 07:17 PM   #6
Old car's Avatar
Thanks Herk. Looks like the air conditioner is okay. Television may not have been so lucky. The fridge is still undecided. The "auto" light on the fridge is on and there is another light on as well. It is marked "check gas when flashing". The gas is turned off at the propane tanks and the light is not flashing. Going to check again in awhile to see if the fridge starts cooling at all. Looks like all the fuses are in tack.
Randy and Patty
Old 07-08-2012, 07:28 PM   #7
sherdep's Avatar
not sure what TV you have but could be as simple as the power supply or the latter part - TV.
I would try plugging the tv into an extension cord just to make sure, Which TV do you have?
Old 07-08-2012, 08:17 PM   #8
Old car's Avatar
Toshiba 32 and it will not work on the extension cord either. Thanks for the tip!
Randy and Patty
Old 07-09-2012, 07:32 AM   #9
Herk7769's Avatar
OK, the check light on with no propane is what you want as you are checking the cooling from AC only.
A thermometer in the freezer will let you know pretty quick if the ac portion of the fridge controller got fried. If it will not cool on AC; there is an AC fuse that "hopefully" blew and saved the control board and heater.
Once you determine if the AC is good or not; press the "GAS" button; turn on the propane and make sure the range burners light. Soon after, the check light should go out and the fridge hopefully will stay (or start) cooling on propane and battery,
Old 07-09-2012, 08:17 AM   #10
jimh's Avatar
u may want to check the fuses or breakers on the converter...u may get lucky.
don't understand how u r loosing 12v when u plug into 110v; my old trailer would drop the battery out when i plugged in but the one i have now keeps the battery in the circuit when pluged 110.
the television usually stays on so that it can sense the remote signal. u may want to check a fuse there as well.
all ur circuit boards (except on the microwave and converter) come form the battery. hopefully, that protected u.
jimh is offline   Reply With Quote
