Old 02-18-2016, 07:28 AM   #1
Fluffywhitedogs's Avatar
Power converter loud hum
I normally keep my Clipper 17bh plugged in year round. I had it out last weekend, brrrr, very cold weather but I had power, and I was plugged in and toasty all weekend. When I got home Sunday night, though, I forgot to plug back in.
It's now Thursday morning, and I remembered and went out to do so. When I did, there was quite a loud buzz coming from the converter.
I googled it and found a couple of hits on "buzzing and getting very hot" so I unplugged it again as I have to go to work and don't want a fire! My battery level is still at 3/4 so I'm not worried about it running out.
It's well below freezing right now. I don't know if it makes any sense but my instinct is to try again on the weekend when it's supposed to get well above freezing? I don't know, start from warmish rather than frozen?
Any input? I hope the converter isn't dying because the rig is 13 months old and I imagine the warranty on it is a year?
Carmen
Fluffywhitedogs is offline   Reply With Quote
Old 02-18-2016, 08:02 AM   #2
Flybob's Avatar
If the trailer was not plugged in for a while, there was probably some battery drain and once plugged in the converter would go into charge mode. If you have a thermally controlled fan and it was cold outside the fan may not kick on and you would hear the converter hum. Normally (warmer temp) during high charge the converter would warm up and trigger the fan. Just one possibility.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
Old 02-18-2016, 08:46 AM   #3
SeaDog's Avatar
Most converters like your home battery charger do buzz when charging a battery. At some point as the temp of the converter comes up the fan should start which may mask the buzz from the converter. My Winnebago and my Flagstaff both make noise when charging.
Retired Navy
Jake my sidekick (yellow Lab)
2016 Flagstaff 26 FKWS
Old 02-18-2016, 11:42 AM   #4
The hum is much louder than the normal charging hum...
Old 02-18-2016, 11:48 AM   #5
Flybob's Avatar
What is the battery voltage with the converter off? Is it possible you left something on and the battery is almost dead and you are attempting to charge a bad battery?
TST Tire Monitors
2 100W solar panels
Old 02-18-2016, 12:09 PM   #6
I haven't tested voltage but everything was off, the meter is showing 3/4 power, and everything is working.
Carmen and the pack
2015 Coachmen Clipper 17BH
2003 Toyota 4Runner Sport V6
Old 02-18-2016, 12:22 PM   #7
2012 Solera
Converter fan out of balance or hitting something? Maybe a frost issue on the fan? I have not experienced with a converter, but have had a few computer fans suddenly start up very loud. Sometimes a good "thump" on the case fixes...
JLeising
2012 Solera "S"
Calif SF Bay Area
JLeising is online now   Reply With Quote
Old 02-18-2016, 12:23 PM   #8
SeaDog's Avatar
You can't really go by the installed battery indicator, you need to put a multi meter on the battery to find out what their actual voltage is.
Retired Navy
Old 02-18-2016, 12:51 PM   #9
I was afraid you'd say that. I don't have a multi meter and I'm not sure how to use one. Not rocket science, I'm sure, just never done it!
Carmen and the pack
Old 02-19-2016, 12:06 PM   #10
Just to update: it's warm so I plugged in today and everything was quiet and smooth, just the normal hum. I guess (I hope) she was just protesting the cold. Like everyone else
Carmen and the pack
converter, power
