Old 08-13-2014, 04:33 PM   #1
iluvlcy's Avatar
Power cord melted
We were packing up after a 7 day trip, went to disconnect power cord and..
Name:	ImageUploadedByForest River Forums1407965366.952176.jpg
It melted to our portable power surge protector, we never had a power interruption so the surge protector did its job question is do we need new power cord or can we replace the end? Same with the progressives protector do we need to replace it as well? And what do you suppose happened?
Pam & Don
2003 Ford Expedition EB
2011 Rockwood 2304s
108 days camped 2013
74 days camped 2014 so far
iluvlcy is offline   Reply With Quote
Old 08-13-2014, 04:39 PM   #2
RSchleder's Avatar
No clue on what happened. If you can find a replacement end, replace the burnt one, if not, your stuck with buying a new power cable. The Progressive should be fine unless there are "weird" or no indicators on the read out.
Days camping (2016)----181 days
Days camping (2017) --- 82 days
2016 Wildcat MAXX 28RKX (33' TT), 2007 13' Scamp
2015 Ram Laramie Hemi, w/air suspension
30 years RV'ing
11 different RV's
RSchleder is offline   Reply With Quote
Old 08-13-2014, 04:48 PM   #3
NELA
Weezer's Avatar
You should be able to buy a new end for it. We pulled away with our power cord still hooked up (blushing red) and thankfully the only damage was that it broke the plug and prongs...NO damage to the 5er receptacle.
We priced the replacement ends, and with the cost of the plug, plus paying someone to wire it on, it was actually cheaper to buy a new cord.
We'll eventually get the original cord fixed for a back up...for now it's piled up in Sneak's shop.
If age is a state of mind, and I've lost my mind, I'm AGELESS, right?
Give me 40 acres and I'll turn this rig around:
Flagstaff 5er 2014 8528 IKWS, Platinum Package, Regency Interior "Buffy"
F250 Super Duty 2013 Tuxedo Black "Biff"
Days camped 2014: 30
Weezer is offline   Reply With Quote
Old 08-13-2014, 04:49 PM   #4
NELA
Weezer's Avatar
Wait...yours *looks* like 30 amp, from the size of the wire....it might be a much cheaper fix for you. We're 50 amp.
Old 08-13-2014, 05:09 PM   #5
Heat would be generated by any connection with corrosion or dirt that has a higher than normal resistance. If you get them apart, check both sides.
2014 Blue Ridge 3715BH <- Read the saga
2013 Sierra 3500HD Denali CCLB DRW 4x4 Duramax w/ Reese 20K
Camped: 2016=6, 2015=9, 2014=27
USN Retired (26 years), but not Retired retired
Home Port Orlando
Narboza is offline   Reply With Quote
Old 08-13-2014, 09:46 PM   #6
iluvlcy's Avatar
Ok we got them pried apart and oh my gosh!
Name:	ImageUploadedByForest River Forums1407984270.213126.jpg
So we have the part to replace power cord end bot what about the power guard? Can we replace its plug or should we by a new one? I am amazed, have no idea when it happened like I said never a power interruption. Crazy!
Pam & Don
2011 Rockwood 2304s
Old 08-13-2014, 09:59 PM   #7
doodler's Avatar
Sometimes inside the female end, will spread apart therefore having a loose connection, loose connections will get hot and melt.
doodler
doodler is offline   Reply With Quote
Old 08-13-2014, 10:38 PM   #8
fast murray's Avatar
I'd go ahead and replace both ends. It's easy and inexpensive. If the surge protector didn't cut power, the problem apparantly existed in the female plug.
2004 Wildcat 28BH
2012 Ram 2500 CCSB 6.7CTD
fast murray is offline   Reply With Quote
Old 08-17-2014, 10:31 PM   #9
BurgPath's Avatar
I had a similar issue a month ago. I was using a SurgeGuard basic protector and it melted the plug making the flat blades loose in the plug.
I contacted the manufacturer of the Surge Protector and they stated it was due to a poor connection. That my plug blades were likely corroded a bit and cause electrical resistance.
I replaced the end of my 30 amp power cord and moved up to a better surge protector. Spent 10 days in Myrtle Beach and ran the AC to death. Plug and surge protector never got hot, worked as it should.
Kevin (BurgPath)
2018 Grand Design Reflection 337RLS
2017 Ford F350 CCSB
Mods and Pics
BurgPath is offline   Reply With Quote
Old 08-17-2014, 11:40 PM   #10
iluvlcy's Avatar
Thanks, we replaced the cord end still deciding what to do to surge replace plug or unit. I will definatly pay closer attention to the plug prongs from now on, It was always hot when we unplugged from surge guard now I know why!
Pam & Don
2011 Rockwood 2304s
power
