There could be a problem with the 7-wire harness but--I'd think this was unlikely as you state that the TT battery will charge using the tow vehicles 7-way plug. "Interior power does work on camp hookup." I will understand this to mean your 12v lighting system which would obtain power from your convertor, not the battery while on shore power. I believe that is an internal switch on your convertor that switches over between power supplies. I have found, at times, that a wire was not hooked up at a junction box somewhere near the front of the unit. Units with the "covered under-belly" are harder to find for sure. This it the point where the wiring from your pigtail (the 7-wire connector made to your TT) connects to the TT's wiring. You, or someone, will have to trace the wiring back from the tow vehicle's 7-wire plug all the way to the convertor on this one. Make sure that ALL of the pins at the 7-wire connector of the tow vehicle are working before starting this process.
