Old 08-01-2015, 02:46 PM   #1
Power Drain
We are newbies. We just purchased a 2014 Coachmen Encounter 37TZ. Our house batteries are discharging almost completely (down to 1/3) on a daily basis, while the coach sits. We have to start and run the coach for an hour or more, or take it on a short trip, each day, in order to recharge the house batteries. We have no lights left on, or anything else we can think of, that would cause a battery drain. This does not seem normal. Any ideas on the cause? Thanks in advance for any help.
billparker23 is offline   Reply With Quote
Old 08-01-2015, 02:55 PM   #2
Flybob's Avatar
Are you sure you are reading your monitor panel correctly. Many monitor panels have one scale for tanks and another for Battery. Running the RV ( assume at idle) for an hour should not take batteries from 1/4 to full.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
Old 08-01-2015, 03:23 PM   #3
Thanks for the reply. I believe I am reading it correctly. It is the battery monitor for sure. It has four red lights from 1/4, 1/2, 3/4 and full. Running it an hour to an hour and a half gets it to 3/4. But, the next day, it will be down to 1/4.
Old 08-01-2015, 03:53 PM   #4
Cypressloser's Avatar
Location: Alberta - East of the Rockies, West of the Rest
Running the engine for an hour or so does very little to charge the batteries, it takes likely a full day to charge them completely. Also a low SOC (state of charge) is bad for the longevity of the batteries.
You have a few options here:
-Solar panels
-Battery disconnect (no option - a must have)
-keep the MH plugged in to keep the batteries charged and maintained
Also with constant charging and discharging water will evaporate at a high rate from the batteries and needs to be checked often (unless you have AGM batteries).
2018 RAM 5500 Laramie CC
Sold: Riverstone Legacy 38RE, 960 Watt Solar, 6x6 Volt AGM Battery Bank, Freedom SW 3012 Inv/Charger
Ordered: 2021....
Cypressloser is offline   Reply With Quote
Old 08-01-2015, 04:17 PM   #5
Get a real battery meter , those lites are a joke !
wanderingbob is offline   Reply With Quote
Old 08-01-2015, 05:48 PM   #6
Power Drain
You're getting a surface charge reading from running the engine. You need to 1) get a battery charger and charge it to full, this may take a couple of days if it's at 1/4. 2) when you reinstall the battery, disconnect the negative cable when not in use or install a battery disconnect switch.
There are many things that will put a parasitic load on a battery, such as the CO2 detector, radio, TV, antenna , microwave ( all have little red lights or clocks on them).
Your first problem is that you're not truly getting your battery back to full. Use a good three stage charger for this.
Second you have parasitic draws. You can isolate me and pull the fuses, or simply leave the negative cable off so it can't drain down the battery.
2007 Rockwood 1640 LTD Popup -- SOLD
2004 Bantam 19 HTT -- SOLD
2015 Coachmen Freedom Express 292BHDS -- SOLD
2013 RAM 2500 CTD
2018 Prime Time Crusader 319RKT
Loraura is offline   Reply With Quote
Old 08-01-2015, 09:31 PM   #7
Power Drain
Thanks much for the very informative responses. You provided much information that I was unaware of. We will get a good battery charger and a means of switching off or disconnecting the negative terminal, if necessary.
Old 08-01-2015, 09:38 PM   #8
Crockett's Avatar
one parasitic drain covered in an earlier post, the dometic refer no longer has a switch on a heat element for condensation on the door sealing surface.
Crockett is offline   Reply With Quote
drain, power
