Old 05-29-2013, 08:19 PM   #31
Denver, CO
garbonz's Avatar
Originally Posted by herk7769 View Post
Robert,
These alternators are designed to work with specific battery types and use external regulators to manage the amperage output by user programmable stages based on the battery type.
Balmar Max Charge Multi-Stage Voltage Regulator
They do not work with multiple battery types at the same time (starting and deep cycle in the same network) since the programs are different and different regulators (with the proper charging program) are required to avoid destroying one or the other.
Okey dokey. I shut up now. I don't see an acceptable solution for this fellow then without, a big battery bank although I like the idea of the inverter in the TV and a 110 volt line to the TT.
BOB
2017 Fuse 23T
Old 05-29-2013, 08:33 PM   #32
Herk7769's Avatar
BOB
Bob, it is kinda "lose; lose" with a 120 VAC only fridge.
Barry's comment is also valid. Short legs to the campground (no more than 5 hours) or a pair (or more) high capacity batteries and an inverter seems to me to be the only options he has.
The inverter in the TV should also work as the amperage would be fairly low; thus voltage loss would also be low.
HAM CALLSIGN - KC3FFW
Old 05-29-2013, 10:02 PM   #33
jlgail4309's Avatar
So bypass the batteries on the TT. Run a large power wire for the TV battery to the inverter. Would that be possible with a HIGH OUTPUT ALTERNATOR 250AMP.
2008 Jeep Grand Cherokee Diesel
2013 Salem Cruise light 19bh
Hensley Cub hitch ,
jlgail4309 is offline   Reply With Quote
Old 05-29-2013, 10:30 PM   #34
Herk7769's Avatar
Sounds like an expensive experiment in my opinion.
You, of course, are free to do as you will.
I would advise against it.
I still think the best bang for the buck would be a pair of matched 200 AH batteries and shorter legs if needed.
Good luck.
Old 05-30-2013, 11:54 AM   #35
Denver, CO
garbonz's Avatar
Still, Wouldn't an inverter in the engine compartment, with short 12 volt leads, and a 110volt wire back to the camper with a plug and a switch be the cheapest solution, given that OP already has the inverter? The OEM alternator should be able to keep up with that much drain, I would think. No connection to the TT battery at all. Maybe need a higher output alternator
Maybe I am missing something...
2017 Fuse 23T
Old 05-30-2013, 07:08 PM   #36
jlgail4309's Avatar
I'm not sure both sound like they would work. The 250amp alternator in only 300.00 me and my family not have to walk priceless. But most of my trip are only a couple of hours. About 1 or 2 trips a year will be 15 hours one way. Either Destin Fl or Colorado Springs most of the time. My normal on the long trips is halfway and camp. My backside has had enough at 8 hours.
I would like to say thanks for all the comments.
Hensley Cub hitch ,
