Old 05-28-2013, 08:44 PM   #1
jlgail4309's Avatar
Power inverter that runs the refrigerator
Power inverter 800 watt that runs the refrigerator while i'm traveling. It works great for about a 100 miles then it stops working. I have better luck if I turn the refrigerator for a couple of day. I wondering if it the inverter or my alternator or need another battery.
2008 Jeep Grand Cherokee Diesel
2013 Salem Cruise light 19bh
Hensley Cub hitch ,
jlgail4309 is offline   Reply With Quote
Old 05-28-2013, 09:03 PM   #2
Perhaps it's turning off because the battery driving it is becoming discharged. Either your tow vehicle isn't providing power to the RV while towing, or it's not providing the 40+ amps that would be required for 500 watts at 12v.
Old 05-28-2013, 09:06 PM   #3
Herk7769's Avatar
Yes, there is no way a tow vehicle alternator will replace that much power consumption from the trailer battery.
Lou & Freya the wonder dog
2019 Flagstaff 8529FL
Old 05-28-2013, 09:07 PM   #4
jlgail4309's Avatar
Thinking about taking it to the dealer they installed the inverter and wired it up.
Hensley Cub hitch ,
Old 05-28-2013, 09:10 PM   #5
jlgail4309's Avatar
Herk what do you suggest it a small frige.
Hensley Cub hitch ,
Old 05-28-2013, 09:15 PM   #6
Is this a residential fridge (eg, only works on 120v)? Doesn't it have the ability to run
on propane while you're traveling? That's what most of us do.
Old 05-28-2013, 09:17 PM   #7
jlgail4309's Avatar
It a residential only I complained so they put the inverter on the trailer. I haven't used it a lot. Now I having problems .
Hensley Cub hitch ,
Old 05-28-2013, 09:21 PM   #8
I would use a meter and check pin 4 on your TV to make sure your vehicle is putting out 12 volts and charging your batteries when running. Sounds like it is possibly not putting out any charge line.
Walter & Donna
2011 CC LB RAM 3500 CTD 6.7L DRW
2013 Cedar Creek 38FL
2017 Days Planned: 135
38FLCamper is offline   Reply With Quote
Old 05-28-2013, 09:23 PM   #9
Herk7769's Avatar
Well, if it is 110 only, you are kinda stuck.
1) pack it with ice in ziplock bags so the heater does not run as often and the water does not run all over the place
2) More batteries (deep discharge) not dual purpose (or starting batteries). The POS one that you have now is most likely 60 AH or less. A pair of 100 AH batteries would do the trick.
Trojan Battery Company
3) Solar panels on the roof to assist keeping the battery bank up.
Old 05-28-2013, 09:29 PM   #10
jlgail4309's Avatar
Thanks it 110 thinking a second battery. I was wondering it they make a high output alternator.
Hensley Cub hitch ,
Old 05-28-2013, 09:31 PM   #11
jlgail4309's Avatar
I will check that out. Thanks
Hensley Cub hitch ,
Old 05-28-2013, 09:35 PM   #12
Herk7769's Avatar
The problem with alternators is that it can't tell you have a trailer deep cycle battery. It is a single stage charger that works off the average voltage across the truck. Once the truck battery is "full"; it tapers the current off. It is OK for keeping a full battery full (and even some light charging duties), but replacing a 40 amp draw is just not possible. Here is a more technical reason why it won't work even with a "heavy duty alternator."
File Type: pdf Automobile Alternators as Chargers.pdf (805.9 KB, 38 views)
Old 05-28-2013, 09:48 PM   #13
jlgail4309's Avatar
Herk you make it easy even for dummies like me. THanks for all your help.
Hensley Cub hitch ,
Old 05-28-2013, 10:08 PM   #14
Herk7769's Avatar
There is danger in trying to simplify complex math and/or physics to make the general concepts easier to understand. "Close enough" works for most folks, but there are always purists who will jump in with a "not so fast."
As long as you get the gist of what is going on, I feel it is close enough for government work...
You really don't need to know how to build a clock to tell the time.
(Although if you want to know how, I can show ya!)
Old 05-28-2013, 10:18 PM   #15
jlgail4309's Avatar
I agree !! Thanks for making to easy.
Hensley Cub hitch ,
Old 05-28-2013, 10:37 PM   #16
Herk7769's Avatar
[QUOTE=38FLCamper;387037]I would use a meter and check pin 4 on your TV to make sure your vehicle is putting out 12 volts and charging your batteries when running. Sounds like it is possibly not putting out any charge line.
This should definitely be checked. In this case "some" is better than "none".
If the truck's charge line is not functioning, a 40 AH draw will kill a fully charged battery in a couple of hours. WITH the charge line you might just get enough extra juice to get you to your destination before the camper's battery is dead.
Here is how to figure it out.
Suppose you have a 100 amp hour battery that is fully charged when you leave (big assumption I know, but you have to start some where).
Now you pull 40 amps out to run the camper and the inverter (500 watt load).
Using the attached graph, you will see that a 100 AH deep discharge battery simply can not serve up that much power without a severe reduction in the ability to continue to serve it up. (trying to think of a good example here - maybe like trying to suck the juice out of an orange. At first there is a lot of juice, but even though there is a lot more juice in there you have to work harder and harder to get the deep juice out and the rate at which you can get the juice drops off. That sucks but it is the best I can do on short notice.)
So anyway, using the graph and a 40 amp draw on a 100 AH battery, you will see that the ACTUAL capacity is reduced to 48 AH and NOT 100 AH (Calculated with a 5 amp load in the example). (Known as the the Peukert Effect - see article)
So at 40 amps, the battery will go from fully charged to fully dead (voltage below 10.5 volts) in 40 amps into 48 amp hours or 1.2 hours.
Now, in your case, I am sure you don't have a 100 AH battery so the time would be much less. However, the 40 amp draw is not all the time; only when the compressor/heater (whatever is in your fridge) is drawing power.
So say it is only on 1/4 of the time; BUT it is at the full 40 amps. Now it gets a bit dicey since the battery can start to recover between hits (some juice can leak out of the deep pulp and be available again).
However for simplicity, lets say the average time will be 2 times longer than the "all the time on" or about 2.5 hours to a dead battery. Add some "add" from the ruck's charge line and you might get 4 -5 hours before dead.
Was that helpful?
Name:	battery voltage and capacity Curve vs Discharge Rate.jpg
Old 05-28-2013, 10:52 PM   #17
jonnys_walkers's Avatar
High Output Alternator
They are expensive. It puts out 300 Amps
MG Industries Inc.
Never enough camping!!
jonnys_walkers is offline   Reply With Quote
Old 05-29-2013, 06:08 AM   #18
Wanna Be Camper
SaskCampers's Avatar
It could be how the inverter is wired too. If it has a fairly long 12v run with undersized wiring, the voltage drop will be such that the inverter will shut down well before the battery is dead as the 12 volts will seem artifically low to the inverter.
John & Deb
2011 Flagstaff V-Lite 30WRLS
Old 05-29-2013, 07:27 AM   #19
You certainly can't come to that conclusion unless you know how long he intends to drive in this configuration.
Old 05-29-2013, 07:31 AM   #20
Good point, although that would buy him just a bit more time at best.
Another thought. In a different thread just like this, someone suggested that the inverter be installed in the tow vehicle and then run a 120v "extension cord" back to the RV to
power the fridge. With that configuration a larger alternator can definitely power the inverter as long as needed. You'd just need to be careful not to drain the truck batteries when you shut the truck off.
