Old 05-28-2013, 09:44 PM   #1
jlgail4309's Avatar
Power inverter that runs the refrigerator
Power inverter 800 watt that runs the refrigerator while i'm traveling. It works great for about a 100 miles then it stops working. I have better luck if I turn the refrigerator for a couple of day. I wondering if it the inverter or my alternator or need another battery.
2008 Jeep Grand Cherokee Diesel
2013 Salem Cruise light 19bh
Hensley Cub hitch ,
jlgail4309 is offline   Reply With Quote
Old 05-28-2013, 10:03 PM   #2
Perhaps it's turning off because the battery driving it is becoming discharged. Either your tow vehicle isn't providing power to the RV while towing, or it's not providing the 40+ amps that would be required for 500 watts at 12v.
Old 05-28-2013, 10:06 PM   #3
Herk7769's Avatar
Yes, there is no way a tow vehicle alternator will replace that much power consumption from the trailer battery.
HAM CALLSIGN - KC3FFW
Old 05-28-2013, 10:07 PM   #4
jlgail4309's Avatar
Thinking about taking it to the dealer they installed the inverter and wired it up.
Hensley Cub hitch ,
Old 05-28-2013, 10:10 PM   #5
jlgail4309's Avatar
Herk what do you suggest it a small frige.
Hensley Cub hitch ,
Old 05-28-2013, 10:15 PM   #6
Is this a residential fridge (eg, only works on 120v)? Doesn't it have the ability to run
on propane while you're traveling? That's what most of us do.
Old 05-28-2013, 10:17 PM   #7
jlgail4309's Avatar
It a residential only I complained so they put the inverter on the trailer. I haven't used it a lot. Now I having problems .
Hensley Cub hitch ,
Old 05-28-2013, 10:21 PM   #8
I would use a meter and check pin 4 on your TV to make sure your vehicle is putting out 12 volts and charging your batteries when running. Sounds like it is possibly not putting out any charge line.
Walter & Donna
2011 CC LB RAM 3500 CTD 6.7L DRW
2013 Cedar Creek 38FL
2017 Days Planned: 135
38FLCamper is offline   Reply With Quote
Old 05-28-2013, 10:23 PM   #9
Herk7769's Avatar
Well, if it is 110 only, you are kinda stuck.
1) pack it with ice in ziplock bags so the heater does not run as often and the water does not run all over the place
2) More batteries (deep discharge) not dual purpose (or starting batteries). The POS one that you have now is most likely 60 AH or less. A pair of 100 AH batteries would do the trick.
Trojan Battery Company
3) Solar panels on the roof to assist keeping the battery bank up.
Old 05-28-2013, 10:29 PM   #10
jlgail4309's Avatar
Thanks it 110 thinking a second battery. I was wondering it they make a high output alternator.
Hensley Cub hitch ,
