Old 06-03-2012, 06:33 AM   #1
Power issues
We own a 2004 Cardinal 5th Wheel. The outside porch light, the overhead kitchen light and the storage compartment light are not working. I have checked all breakers and fuses and even changed out the gfi plugs. Has anyone else had this issue and can tell me how to fix it?
Thank you
King DanII is offline   Reply With Quote
Old 06-03-2012, 06:57 AM   #2
KyDan's Avatar
Hello King, mind if I call you dan???
OK, first let's have a lesson in electric in an RV.
In most RVs the lights are 12v. (Unless someone with an 04 Cardinal posts here
and says I'm wrong?)
That means
A- the lights are not connected in any way to any outlets GFI or not.
B- the lights are on fuses not circuit breakers (12v stuff are generally on
fuses and 120v items are on circuit breakers)
C- if you've checked fuses with a meter and know they are good, it's time
to dig deeper. If I were you, I'd remove the light fixture and check the
wire connections at the rear. You're looking for a loose connection.
Next pull the switch and check for loose wires behind it and don't forget
to check for loose wires behind the storage light too.
It's a treasure hunt and it's up to you or a dealer to find the loose
Good luck and welcome to Forest River Forums!
Please post back and tell us what you found, we'd love to know how this turns out.
Dan & Rita D
2004 5.3L Silverado 1500 ext. cab 2WD
Blue Ox WD hitch, AirLift load levelers
2013-41, 2014-31, 2015-40, 2016-38
Old 06-03-2012, 06:59 AM   #3
Herk7769's Avatar
You may need to pull the power center from the wall to access the rear of the converter. There are most likely additional "pigtail" circuits with fuses located back there.
Old 06-03-2012, 10:50 AM   #4
Dave_Monica's Avatar
Sounds like loose wiring connections or more likely, corrosion that's causing a poor ground.
led pad
