Old 05-02-2014, 07:22 AM   #1
Power outlet issue
It seems like I have blown a breaker in the back. Nothing was flipped in the breaker box but I went ahead and reset all of them. I also checked all of the GFCI outlets and reset them. Still no power to half of the outlets. We are completely new to this camping life and have no clue what to do next. Any suggestions?
FogueTravelingAbode is offline   Reply With Quote
Old 05-02-2014, 08:42 AM   #2
What are you in? Do you have an inverter? If so check the reset switch in top.
Old 05-02-2014, 08:47 AM   #3
AKA: 'tiredTeacher
awellis3's Avatar
Originally Posted by FogueTravelingAbode View Post
Any suggestions?
Welcome! Yes, a suggestion: include in your posts make, model, year of RV in question. Also of any appliance you need help with. This allows the right member to zero in on your problem and give you a definitive (usually) answer.
Wright and Penny
(with Fitz and Lizzie, the camping kitties)
Richmond, Va.
2010 Tundra 4X4 5.7L V8
2014 Rockwood 2604WS
Life is a cruel teacher. She gives the test first; the lesson then follows.
awellis3 is offline   Reply With Quote
Old 05-02-2014, 08:48 AM   #4
If you can add your RV to your signature or something, it will help others help you. Like Phil said, those outlets could be running off an inverter and depending on your inverter, you could also have a GFCI reset switch on the inverter's outlet.
2014 Georgetown 351DS
-TruCenter -Front/Rear CHF -Hellwig Links -Tiger Trak -Ran McNally GPS -ScanGauge -Truck Systems TPMS -5 Star Tune
alparmer is offline   Reply With Quote
Old 05-02-2014, 08:59 AM   #5
wmtire's Avatar
We're here to try to help. It's pretty important though, that we get as much information as possible in order to offer an informed opinion....like your make/model RV......and if you are using 30 amps or 50 amp service.....what/where you are currently plugged into (camp ground outlet, household outlet, generator, inverter, etc.).
A common culprit for outlets not working is a tripped GFCI on one of the master outlets. If the master GFCI trips, then all the other outlets downstream of it on the same circuit will not work. USUALLY there are two master GFCI outlets, one in the bathroom, and one in/near the kitchen.
I would advise to check both places for a tripped GFCI.....and try to reset them We also see bad GFCI outlets, and loose wiring..even on new RV's. It happens.
Another question, is it just the outlets not working...or are there more AC electrical appliances not working too (ie television, microwave, Air-conditioner).
If you are using a 50 amp service, the problem may lie in one of the two 120 volt lines that are providing service to your RV.......but we'll stay clear of that right now until you have time to read this and hopefully provide more information.
Don't stress. Everyone will try to help.
2011 Flagstaff 831 RLBSS
Iíve lost my scapegoat.
Old 05-02-2014, 12:46 PM   #6
bikendan's Avatar
Ditto. without knowing what kind, year, make and model of RV you're talking about, we can't really know how to help you.
some RV's have inverters so the outlets can run off of a bank of batteries. this is usually with motorhomes.
if you just have a converter and no inverter, then that's different.
Dan-Retired Firefighter/EMT
Equalizer WDH and Prodigy BC
power
