Old 06-08-2013, 08:17 PM   #101
BandJCarm's Avatar
OK.
EMS PT-30C it is.
Going once............going twice..............
BandJCarm is offline   Reply With Quote
Old 06-08-2013, 08:23 PM   #102
QCCowboy's Avatar
Originally Posted by BandJCarm View Post
OK.
EMS PT-30C it is.
I would recommend the hardwired unit, but either way the PI is a great choice.
Jack of all trades - Master of none
2012 F350 CC DRW - 6.7L PSD
2014 Sabre 36QBOK
QCCowboy is offline   Reply With Quote
Old 06-08-2013, 08:43 PM   #103
TURBS's Avatar
I'm with qc on this one!
Old 06-08-2013, 09:03 PM   #104
BandJCarm's Avatar
Every time I get close, another question..................
So, why the hardwired? The hardwired installation instructions say I have to cut the power cord, wire this thing into it somehow, and the other unit is already a part of the power cord.
I'm trying to get what I need, but I can't figure out where the hardwired unit goes, how to wire it in since the specs say "cut the power cord" (Which makes me uncomfortable), or why it's better.
Can you help me with these 3 questions?
And thanks, so far.
Old 06-08-2013, 09:05 PM   #105
TURBS's Avatar
So, why the hardwired? It says I have to cut the power cord, wire this thing into it somehow, and the other unit is already a part of the power cord.
And thanks, so far.
I put mine behind the converter.
Inside my camper.
Old 06-08-2013, 09:07 PM   #106
TURBS's Avatar
The orange wire needed to be cut
Old 06-08-2013, 09:08 PM   #107
QCCowboy's Avatar
And thanks, so far.
Tubbs has some great pics. You will need to cut the power between between the incoming power and the converter/power panel. Why? It is always there, you won't forget it, it won't get wet and potentially fault, and if you get the optional remote display you can read all of the information about the electrical system from inside the camper. Oh, it won't "get legs" either.
2014 Sabre 36QBOK
Old 06-08-2013, 09:08 PM   #108
TURBS's Avatar
Old 06-08-2013, 09:09 PM   #109
TURBS's Avatar
Old 06-08-2013, 09:09 PM   #110
QCCowboy's Avatar
Told you he had pics!
2014 Sabre 36QBOK
Old 06-08-2013, 09:10 PM   #111
TURBS's Avatar
Lol tubbs!
Old 06-08-2013, 09:10 PM   #112
Always Learning
Why hard-wired and why is it better is twofold-
1) it's always there. You don't have to plug it in each time that you get setup nor take it down when you break down.
2) it can't grow legs and get stolen when it's hanging from the campground's power box. I don't know if this legitimately happens, but the possibility is there.
However, if you're not comfortable cutting your power cable inside the camper, then the portable is likely the right product for you. You shouldn't tackle a major electrical project unless you have someone knowledgable to help OR pay the dealer to do it.
Old 06-09-2013, 08:39 AM   #113
10x
Originally Posted by f1100turbo View Post
Whats that switch next to the display for?
2014 XLR 27 HFS
2010 F250 4x4 Crewcab Turbo Diesel
10x is offline   Reply With Quote
Old 06-09-2013, 08:53 AM   #114
It's the "bypass". It allows you to tell the EMS to turn on the power to the RV even when it says it's not safe to do so. One would use this if the EMS is faulty and needs to be sent in for service or if you, in your infinite wisdom, have decided to accept the risk of a true fault (such as a generator without the needed bond between neutral and ground).
Old 06-09-2013, 08:54 AM   #115
TURBS's Avatar
Ha ! Thats the secret turbo button!
Actually wfco converters are known at least in my experience to have cheap blow up any minute computer fans for cooling.
So I added a higher volume fan that I can turn on manually to keep things cool at my command.
Turbs
Old 06-09-2013, 08:56 AM   #116
TURBS's Avatar
Originally Posted by BarryD0706 View Post
It's the "bypass". It allows you to tell the EMS to turn on the power to the RV even when it says it's not safe to do so. One would use this if the EMS is faulty and needs to be sent in for service.
No the rocker switch next to the ems panel is what I think he was referring to.
Old 06-09-2013, 09:20 AM   #117
I never thought I'd see the day when you'd reveal the secret of the magic Turbo switch!
Old 06-09-2013, 09:44 AM   #118
TURBS's Avatar
I've got turbo switches I've not even showed yet!
Old 06-09-2013, 12:01 PM   #119
ernest917's Avatar
If your rig has a power transfer switch, then do as I did.... I purchased the Progressive 50amp hardwired unit and placed it between the power plug in my rig and the transfer switch.... No cutting of power cord required and no worry about someone ripping off my surge protector.... I have already seen it protect my rig 3 times... It's those older CG's and state parks that will get you.....
Personally, I'd NEVER plug into any CG without one. Stop and think - so PI's unit costs $300 or so bucks.. What's the cost (and hassle) of replacing everything in your rig that that unblocked surge zaps??? A friend of mine found out to the tune of around $8K....
ernest917 is offline   Reply With Quote
Old 06-09-2013, 12:52 PM   #120
BandJCarm's Avatar
You guys have sold me on getting one. But I feel like a first grader in an Algebra class.
I don't know if I have a "transfer switch" or not. Guess it's time to go read the manual (though from what I've seen so far of it, I'm not impressed). If I have one, not sure where it is. I'd rather have the PI unit inside, but am NO electrician! And not sure why finding a transfer switch keeps me from cutting and wiring.....but I'm all ears.
