Old 04-15-2013, 04:12 PM   #1
Power Surge Cord
Does one really need a power surge cord to check and monitor power problems in an RV park? I have heard it is a good idea and if so what is the best one without having to take out a loan?? Some of them are pretty pricey!
hihosilver09 is offline   Reply With Quote
Old 04-15-2013, 04:21 PM   #2
TURBS's Avatar
Yes worth the money.
Progressive industries unit.
30 amp units
http://www.progressiveindustries.net/ems_hw30c.htm
http://www.progressiveindustries.net/ssp_30.htm
Old 04-15-2013, 05:02 PM   #3
jimh's Avatar
if u running 30 amp, it is quiet easy to adapt the campground power to a 15 amp socket (like in ur house) and plug a tester into it (mine is yellow and has 3 lights on it) depending on what lights are lit, it will tell u if the circuit is wired correctly. that would be the min i would recommend. that tester is less than $5.
i also have an eaton surge suppressor wired into mine. cost was abt $100 once i wired it in. the suppressor *alone) was abt $70.
you can read horror stories on here abt how someone had their bacon saved by having one. i have yet to experience that.
the image above with 2 lights on is a good circuit.
the lower image, with one light, has an open ground.
actually, u could adapt 50amp down to a 15 amp plug and see if the ground, neutral, and one leg is wired correctly. if it is, u can assume the other leg is ok.
jimh is offline   Reply With Quote
Old 04-15-2013, 05:17 PM   #4
jimh's Avatar
there is another unit out there other than the progressive industries that is sold by campingworld. once it shows all correct and sets the contacter, it can take 8 seconds for it to disconnect if the voltage goes high. i have yet to run a test to see what will happen if the neutral is opened after the contacter closes (provides power to camper). if ur running 50 amps, that can be life changing.
the progressive industries unit seems to be the one that most, on here, recommend. i haven't read any of their specs or run any test on one.
Old 04-15-2013, 05:19 PM   #5
Denver, CO
garbonz's Avatar
30 amp units
EMS-HW30C
SSP-30
X2 and the one with the monitor allow for you to monitor what is going on with your unit and will prevent the problems that can blow all the electric stuff in your unit...
It's kinda mesmerizing to look at.
2017 Fuse 23T
Old 04-15-2013, 06:45 PM   #6
OL Creeker's Avatar
While in Waco recently, some poor guy who didn't believe in surge protectors, wound up with his MH elect system being fried. Apparently, a wire crossed inside this broken down shore pwr box, gave him 220 instead of 120. Not a pretty sight. I also have a polarity checker.
Alan, Kathy & Cooper the camping cat
2014 Cedar Creek, 36CKTS
2013 GMC 2500 Denali
Duramax/Allison
Full timers since 5/30/2013
OL Creeker is offline   Reply With Quote
Old 04-15-2013, 07:37 PM   #7
raytronx's Avatar
Another vote for the Progressive Industries EMS. Lifetime warranty and made in the USA
Ray
Full-Time RVer, loving the life.
raytronx is offline   Reply With Quote
Old 04-15-2013, 08:03 PM   #8
I'll cast a vote for Progressive Industries EMS too.
Old 04-15-2013, 08:16 PM   #9
QCCowboy's Avatar
And another vote for PI here.
Jack of all trades - Master of none
2012 F350 CC DRW - 6.7L PSD
2014 Sabre 36QBOK
QCCowboy is offline   Reply With Quote
Old 04-15-2013, 08:19 PM   #10
Herk7769's Avatar
As long as we are voting; Franks Autotransformer
HAM CALLSIGN - KC3FFW
