Old 02-02-2013, 09:28 PM   #11
You should be able to power everything in the RV with shore power, including moving the slides. I think everyone assumed you didn't have shore power and were looking for a work-around with a tow vehicle battery or jump box.
Shore power provides the AC and your converter creates the DC power which moves the slides.
F-350 Dually
Cedar Creek Silverback
Mazda Miata TOAD for sex appeal
danno2u is offline   Reply With Quote
Old 02-02-2013, 09:33 PM   #12
Ham Radio since 1970
N9ID's Avatar
sideout1951, you ( and the other posters) are correct that it runs off the 12V system. The 12V system will not work without the battery installed.
Mike
Mike & Nena Strong
2013 Cedar Creek 36RE
2012 Chevy Silverado Crew Cab 3500HD Diesel 4WD
Nights camped '14: 51 '15: 134 '16: 149 '17: 171
N9ID is offline   Reply With Quote
Old 02-02-2013, 10:05 PM   #13
You may consider using your tow vehicle and jumper cables connected to the camper battery leads to power the slide motor if you can get close enough. I have used jumper cables to run pumps, lights and other 12v devices without any problems on several occasions.
Sirsea is offline   Reply With Quote
Old 02-02-2013, 10:18 PM   #14
Herk7769's Avatar
Originally Posted by sideout1961 View Post
So by all the responses here I am assume that the slide only runs on the 12v system and not the 110v. Thanks for all the help
My input.
Yes, you can use the 110 volt ac shore power without the battery installed to open and close your slide. It is a strain on the converter (which manufactures 12 volt DC on demand); and its use is not recommended to power your camper without a battery installed.
Having said that, IMO, using the converter to open and close a slide once or twice should not cause any lasting damage.
The caveat is important because "it could;" I just think it is unlikely unless you abuse the converter without a "power sink" like the deep discharge battery.
HAM CALLSIGN - KC3FFW
Old 02-02-2013, 10:20 PM   #15
Herk7769's Avatar
Mike
Mike,
The AC to DC converter will power the DC items in your camper without a battery installed (provided 120 VAC is supplied).
It is just not recommended to use high draw items simultaneously as it could damage the converter.
Old 02-02-2013, 10:53 PM   #16
I store our TT away from our home just a few blocks away with the battery at home when not camping. If I need to roll our slide out, I back my truck up to the hitch area and plug the TT pigtail into the TV. I can roll the slide in and out all I want as long as the engine is running, since the power only flows when the engine is running. I have also done this to power the water pump to flush the toilet and wash hands when I have been doing mods or other stuff with no problems.
Your TV must be wired to charge the TT battery in order for this to work.
2004 F150 4.6 Griffin tuned
2010 Wildwood 24FBS
johnleann is offline   Reply With Quote
