Old 02-02-2013, 03:52 PM   #1
Steve Jackson
sideout1961's Avatar
Power to slide
, I would like to put the slide out to do some work in the camper but the battery is out and stored for winter. Can I just plug the camper in with the power cable or does the battery need to be in to operate the slide?
2011 Dodge Ram 5.7 HEMI
2011 Flagstaff Classic 29bhss
sideout1961 is offline   Reply With Quote
Old 02-02-2013, 04:34 PM   #2
If your TV is wired properly plug it in to the trailer and run the slide out,but the slide will work better with the battery in the trailer and hooked up. Youroo!!
Old 02-02-2013, 04:42 PM   #3
TURBS's Avatar
You would definitely put major strain on the electrical system doing it as you suggest.
Carrying all that electrical load from your tv battery all the way to your slide wouldn't be something I'd like to do unless there was no other way and the slide HAD to be open.
Albeit it can be done.
Jm2c
Turbs
Old 02-02-2013, 08:03 PM   #4
Oklahoma Proud
MillerTime's Avatar
Grab a jump box- Napa has a little yellow one that is on sale for $49.99 that works great. I have used one just like them at work for the past 2 years.
Old 02-02-2013, 08:48 PM   #5
Steve Jackson
So by all the responses here I am assume that the slide only runs on the 12v system and not the 110v. Thanks for all the help
Old 02-02-2013, 08:55 PM   #6
Ham Radio since 1970
N9ID's Avatar
I was told by my dealer that the TV wiring through the plug was not heavy enough to carry the current required to run the jacks and slides. Better to use a jump box like MillerTime suggested.
Mike
Mike & Nena Strong
2013 Cedar Creek 36RE
2012 Chevy Silverado Crew Cab 3500HD Diesel 4WD
Nights camped '14: 51 '15: 134 '16: 149 '17: 171
N9ID is offline   Reply With Quote
Old 02-02-2013, 08:56 PM   #7
Stanleyg's Avatar
It's designed to work on the 12v system.
Stan, Wanda, Sheray, Alex, Nicky, and Macky(the Chorky).
2013 Prime Time Avenger 33BHS
Stanleyg is offline   Reply With Quote
Old 02-02-2013, 09:01 PM   #8
Steve Jackson
Mike
This is why I'll never understand electrical systems. The wiring can't handle the slide but can handle a microwave, AC, refrigerator and other devices in camper.
Old 02-02-2013, 09:11 PM   #9
N9ID's Avatar
I am not sure about all this myself. However, as I understand it, when the RV battery is installed and the TV is connected to the RV, the TV battery is running the inverter/charger to trickle charge the RV battery. The 115V appliances then can run off the inverter and the 12V devices can run off the RV battery. Don't hold me to this; I am not an expert.
I do know that the hydraulic pump in my 36RE is a very high current motor (not sure how high). Say it required 30 amps, which I don't think is unreasonable when the pump is under load. The wire gauge required to carry 30 amps is 10 guage, which is pretty hefty wire. I think most house wiring is done with 12 guage wire. My TV power connector will not carry 30 amps. The wiring is just not heavy enough.
The OP should use a jump box as was suggested. I will now leave the rest of this discussion to folks with more smarts than I have on this topic.
Mike
Mike & Nena Strong
Old 02-02-2013, 09:22 PM   #10
Steve Jackson
Mike
My mistake, I didn't notice in your first message that you were talking about the tow vehicle. I was talking about the 30 amp plug that powers the camper. I'm trying to find out if I just plug it in to the outlet if it would run the slide. But it seems that it only works on the 12v system.
